• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    Accepted Solution
    Displaying surface, point, alignment, etc properties
    1117 Views, 12 Replies
    03-05-2009 09:04 AM
    In pre-2009 versions of Civil3d, when you placed your cursor over a surface, near a point, near an alignment, etc; the surface elevation, point id & elevation, station, offset, etc would be displayed in a "pop-up" window next to the cursor. In 2009, it does not do this. Can I turn this feature on somehow, or did Autodesk eliminate this feature???????
    Please use plain text.
    Distinguished Contributor
    Re: Displaying surface, point, alignment, etc properties
    03-05-2009 09:45 AM in reply to: ragsdale
    Surface Props > Info tab > Show tool tips
    ryan.hawken
    04-20-2011 05:41 PM in reply to: ragsdale
    Despite having the tooltips on, the tootip display does not appear when hovering over a surface. Any ideas on what the problem could be? I'm using C3d 2011
    Product Support
    AlmasSuljevic
    04-21-2011 12:24 PM in reply to: ryan.hawken
    Hi Ryan,
    If you have checked all these places (see link below)
    http://www.civil3d.com/2007/03/who-killed-my-tooltips-four-usual-suspects/
    then let us know if you have Raster Design loaded and do other files get the same issue.
    Almas Suljevic
    Product Support Specialist
    Autodesk Global Subscription and Support
    Autodesk, Inc.
    Please click on "Accept as Solution" if post helped you resolve the issue.
    ryan.hawken
    04-27-2011 09:03 PM in reply to: AlmasSuljevic
    Thanks Almas
    These options were all checked but when I unchecked and checked all of them again, my surface tooltips are back.
    Just a glitch I guess.
    Thanks again
    Ryan
    AlmasSuljevic wrote:
    Hi Ryan,
    Member
    09-13-2011 03:14 PM in reply to: ryan.hawken
    We are running Raster Design and still have this issue in 2011.  Any fix yet?
    Product Support
    AlmasSuljevic
    09-14-2011 05:35 AM in reply to: lonesa
    I think you can run Civil 3D with plain Civil 3D icon (without loading Raster Design). You may also see if you can unload Raster Design CUI (CUILOAD command).
    Almas Suljevic
    Autodesk, Inc.
    09-14-2011 12:15 PM in reply to: ragsdale
    The link that is being provided for www.civil3d.com always takes me to the main Autodesk page for Civil 3D.  Not sure what's happening, but I can't get to a website with www.civil3d.com as the URL.
    Civil 3D 2013 x64
    Civil 3D 2014 x64
    Windows 7 64-bit
    6GB RAM
    Product Support
    AlmasSuljevic
    09-14-2011 12:18 PM in reply to: engrtech
    Try "civil4d" : http://www.civil4d.com/2007/03/who-killed-my-tooltips-four-usual-suspects/ :smileyvery-happy:
    Almas Suljevic
    Autodesk, Inc.
    09-14-2011 12:19 PM in reply to: AlmasSuljevic
    @Almas:  That fixed the link. Thanks!
    I have Raster Design installed, yet when I open Civil 3D (not using the Raster Design shortcut) I still get the ribbon tab for Raster Tools.  Raster Design isn't really loaded, yet the ribbon shows it and almost after every command the ribbon changes to the Raster Tools tab.  Extremely annoying considering I rarely use Raster Design and the fact that I didn't explicitly open Raster Design.
    Does Raster Design change the profile and/or shortcut for Civil 3D?
    Civil 3D 2013 x64
    Civil 3D 2014 x64
    Windows 7 64-bit
    6GB RAM
