• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Expert Elite*
    Neilw
    Re: Displaying Breaklines
    01-06-2013 02:11 PM in reply to: BrianHailey
    "I do agree that it would be nice to be able to highlight or select in the drawing the data that was added but currently that's not available."
    I understood that to be the issue here. There is no way to graphically highlight which lines in a drawing have been used in a surface definition.  The only way to know is to import them from the surface into the drawing.
    I have wished for a way to graphically highlight breaklines in a surface definition. Not only would it serve to identify which breaklines in a drawing have or have not been applied, it also helps when there is a need to remove specific lines from the definition.
    Neil Wilson (a.k.a. neilw)
    Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
    WIN 7 64 PRO
    HP Pavillion h8xt, i7 2600, 12 GB
    RADEON 6450, 1 GB
    http://www.sec-landmgt.com
    Please use plain text.
    *Expert Elite*
    sboon
    01-06-2013 03:14 PM in reply to: Neilw
    I have a Site which includes all of the feature lines that are included in my surface.  I can use the filtering controls in the Quick Select dialog to select only those feature lines.  I can then select the surface, and use the Isolate Objects command.  Now I see only the surface and the feature lines that it was created from.
    *Expert Elite*
    Neilw
    01-06-2013 03:21 PM in reply to: sboon
    How do you know all of the lines in your drawing are in the surface definition? What if someone else created the surface?
    WIN 7 64 PRO
    RADEON 6450, 1 GB
    *Expert Elite*
    Joe-Bouza
    01-06-2013 05:29 PM in reply to: Neilw
    Hi Neil
    If not in the drawing would that not imply a DS? Open source?
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    *Expert Elite*
    Neilw
    01-06-2013 07:04 PM in reply to: Joe-Bouza
    They might be in the drawing but not in the surface definition. How would you know?
    WIN 7 64 PRO
    RADEON 6450, 1 GB
    *Expert Elite*
    sboon
    01-06-2013 07:23 PM in reply to: Neilw
    As I said earlier the site is created as a container for the surface featurelines.  When I am adding breaklines to the surface I use the filtering commands in the Quick select dialog to make sure that they're all included.
    If I wanted to find featurelines that were not part of the surface then I might use the selection process that I described earlier, and then use draworder to move the TIN lines to the front.  Any featurelines that I can still see are not part of the surface.
    *Expert Elite*
    Neilw
    01-06-2013 07:54 PM in reply to: sboon
    Steve,
    I do understand that if you are the one managing the data you can establish schemes to keep track of what lines have been added. That may not be the case if others have worked on the project. In that scenario you may not know what lines have been added or removed and would have to use some other way to make the determination. That is where the graphical feedback would be a great help.
    If I am not understading your solution, could you please clarify how it would work if you know nothing about the history of the surface?
    WIN 7 64 PRO
    RADEON 6450, 1 GB
    Active Member
    01-07-2013 06:45 AM in reply to: Neilw
    BRIAN WRITES: "I do agree that it would be nice to be able to highlight or select in the drawing the data that was added but currently that's not available."
    NEIL WRITES: "I have wished for a way to graphically highlight breaklines in a surface definition. Not only would it serve to identify which breaklines in a drawing have or have not been applied, it also helps when there is a need to remove specific lines from the definition."
    GLEEP WRITES: "Yes! That is the issue here. A simple way of SEEING all the applied breaklines. According to SBOON it looks as though I may be able to set up schemes and sites while constructing my surfaces to keep up with the breakline data. I'm unfamiliar with this language but I will certainly look into schemes and sites pronto.
    I mean, even when I attempt to SELECT the breakline from the data window, nothing seems to be SELECTED on the screen."
    Some days I come to work and imagine Civil 3D is just laughing at me. Like it's got a mind of it's own and knows better than I what needs to be shown. Maybe I need to return to the Etch-A-Sketch.
    *Expert Elite*
    BrianHailey
    01-07-2013 07:14 AM in reply to: gleep
    Unfortunately, when you right click on a breakline in a surface definition and choose "Select" (or something like that), what ends up being selected is the surface itself.
    *Expert Elite*
    Neilw
    01-07-2013 07:16 AM in reply to: gleep
    After thinking a bit more about Steve's suggestion, using Draw Order does allow you to make an effective visual assesment. If a breakline is not included in the surface it will not be masked by the TIN. So Kudos to Steve for that idea.
    We still need some sort of graphic feedback when selecting breaklines in the surface definition though.
    WIN 7 64 PRO
    RADEON 6450, 1 GB
