• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    Disappearing profile labels
    174 Views, 6 Replies
    07-25-2012 11:18 AM
    acad c3d 2013
    My sag and Crest profile labels disappear when opening the drawing.  Has anyone had this problem and if so have they been able to find a fix for it.
    np
    Please use plain text.
    Valued Mentor
    LisaPohlmeyer
    Re: Disappearing profile labels
    07-25-2012 02:12 PM in reply to: NATE_PEARCE
    A couple of questions.
    Does this happen in all your drawings?
    Does this happen on all workstations?
    Have you run an audit?
    Have you run -purge for the regapps?
    If you have run all of these and still have the issue, perhaps post the drawing and one of us will see if it happens to us.
    Lisa Pohlmeyer
    Williamson Co. Dept. of Infrastructure
    Intel i7 3.33Ghz, 16Gb RAM
    Nvidia Quadro 2000D
    C3D 2012 SP3, C3D 2014
    Win 7-64
    Please mark this as the solution if it resolves your issue.
    Distinguished Contributor
    10-23-2012 11:57 AM in reply to: NATE_PEARCE
    I am having the same problem with 2013 - Have you found a solution?
    Sandy W.
    02-12-2013 11:31 AM in reply to: swatfor
    I'm having same issue. The drawing was created in 2012, then updated to 2013. A drawing created in 2013 doesn't have this issue. Computer seeting hasn't changed since 2012. The only change is civil 3D is updated to 2013.  My production drawing is 90% done, so I don't want to rebuild profile drawing.  It seems there are a few thread in this topic, any solution from Autodesk???????
    *Expert Elite*
    02-12-2013 11:45 AM in reply to: Haruko-CTQ
    Can you go back to 2012?
    My suggestion ("solution?") is that: never update when you are 90% done!  We don't even update a project if it's even 10% done.
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    02-12-2013 11:52 AM in reply to: troma
    Thank you for the info. Going back to 2012 is time consuming. I assume many of us work multiple project at time, and some of them are always 90% range. Also muptile people work on the same project, it is hard to keep the version the same.  In this slow time we have project from 2004. we cannot work on LDD.
    I really want Autodesk to look in to this problem.
    Meanwhile my workaround is to create profile in produciton drawing and label them in the drawing rather than base drawing. this way, at lease we only need to open one drawing to fix.
    02-13-2013 06:53 AM in reply to: Haruko-CTQ
    This works for us every time –
    After the 2013 drawing is opened and all the messages are finished:
    1.Go to toolspace
    2.Navigate to the alignment that needs labels to reappear, right-click and synchronize
    3. Repeat for each alignment that you need labels to reappear.
    Its a little time consuming, but ALL the labels reappear. Even any customized labels return to their modified state.
    Sandy W.
