AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Disappeari ng profile labels
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
acad c3d 2013
My sag and Crest profile labels disappear when opening the drawing. Has anyone had this problem and if so have they been able to find a fix for it.
np
Re: Disappeari ng profile labels
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
A couple of questions.
Does this happen in all your drawings?
Does this happen on all workstations?
Have you run an audit?
Have you run -purge for the regapps?
If you have run all of these and still have the issue, perhaps post the drawing and one of us will see if it happens to us.
Williamson Co. Dept. of Infrastructure
Intel i7 3.33Ghz, 16Gb RAM
Nvidia Quadro 2000D
C3D 2012 SP3, C3D 2014
Win 7-64
Please mark this as the solution if it resolves your issue.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am having the same problem with 2013 - Have you found a solution?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm having same issue. The drawing was created in 2012, then updated to 2013. A drawing created in 2013 doesn't have this issue. Computer seeting hasn't changed since 2012. The only change is civil 3D is updated to 2013. My production drawing is 90% done, so I don't want to rebuild profile drawing. It seems there are a few thread in this topic, any solution from Autodesk???????
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Can you go back to 2012?
My suggestion ("solution?") is that: never update when you are 90% done! We don't even update a project if it's even 10% done.
Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
__________________________________________________________
Credit where credit is due! Give kudos or accept as solution whenever you can.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you for the info. Going back to 2012 is time consuming. I assume many of us work multiple project at time, and some of them are always 90% range. Also muptile people work on the same project, it is hard to keep the version the same. In this slow time we have project from 2004. we cannot work on LDD.
I really want Autodesk to look in to this problem.
Meanwhile my workaround is to create profile in produciton drawing and label them in the drawing rather than base drawing. this way, at lease we only need to open one drawing to fix.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
This works for us every time –
After the 2013 drawing is opened and all the messages are finished:
1.Go to toolspace
2.Navigate to the alignment that needs labels to reappear, right-click and synchronize
3. Repeat for each alignment that you need labels to reappear.
Its a little time consuming, but ALL the labels reappear. Even any customized labels return to their modified state.
