• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    Accepted Solution
    Disappearing or moving section labels
    204 Views, 2 Replies
    10-16-2012 03:39 PM
    I have a section view base map that has labeling at the grade breaks of a corridor section. (see correct labels image)
    I made a minor change to the alignment the corridor is using and when I opened my section base, most of the section view labels were messed up. (see messed up labels image)
    Some views were missing labels and in others, they were grouped together in a lump.
    The settings I am using are in the third image. If I checked either the start or end offset box, then unchecked it and closed the dialog, the labels would fix themselves.
    Any ideas on what caused this?
    For reference, there are about 300 section views in this base drawing.
    Thanks.
    Mike Porter
    www.ppeng.com
    Civil3D 2013
    Win 7 Professional - 64-bit
    HP Z400
    Xeon W3550 @ 3.07Ghz
    8GB of RAM
    Nvidia Quadro FX 3800
    Please use plain text.
    Product Support
    Matt_Haokip
    Re: Disappearing or moving section labels
    10-19-2012 08:00 AM in reply to: mikepo
    Hi Mike,
    I am not sure which version of the file you are working on which version of Civil 3D, however you may want to refer to the following blog if applies to your case: http://beingcivil.typepad.com/my_weblog/2010/06/my-section-views-have-moved.html?cid=6a010535cf32f99...
    If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
    Mangkhothang (Matt) Haokip
    Product Support Specialist
    Autodesk, Inc.
    10-20-2012 09:15 PM in reply to: Matt_Haokip
    Figured it out yesterday. All of my corridors were pasted together into one surface in another drawing and I forgot to rebuild that finished surface. After rebuilding, corridor labels updated perfectly.
    Mike Porter
    www.ppeng.com
    Civil3D 2013
    HP Z400
    8GB of RAM
