• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    Digital Terrain Model (DTM)
    335 Views, 15 Replies
    01-09-2013 05:16 AM
    Good morning
    How to generate a Digital Terrain Model - DTM GRID method in AutoCAD Civil 3D 2012 on the basis of X, Y, Z (saved in. Txt)?
    Please use plain text.
    Valued Mentor
    fcernst
    Re: Digital Terrain Model (DTM)
    01-09-2013 06:26 AM in reply to: janic.piotr
    Add as an ENZ point file as Definition data to a new Surface object.
    Ernst Engineering
    Fred Ernst, PE
    C3D 2013 SP1, C3D 2014
    W7x64; i7 8gb; Radeon HD 5700
    www.ernstengineering.com
    Active Member
    01-09-2013 06:38 AM in reply to: fcernst
    When adding pops points erroneous reading the information on file with the points.
    Valued Mentor
    fcernst
    01-09-2013 06:44 AM in reply to: janic.piotr
    Well you just can't throw your hands up in the air now :smileyindifferent:  You have to make sure that text file is in the correct format (i.e, comma delimited, space delimited).
    Look at the C3D Help to make sure you have the correct format. You may have to do a little post processing to that file in your text editor or Excel.
    Ernst Engineering
    Fred Ernst, PE
    Active Member
    01-09-2013 07:48 AM in reply to: fcernst
    The file is OK. TIN model comes out correctly. Only after the creation of GRID surface and attempts to read the file with the coordinates of the points of error pops up.
    Regards
    Valued Mentor
    fcernst
    01-09-2013 12:36 PM in reply to: janic.piotr
    Hi There,
    Ok, so we have the TIN surface built as you first requested...
    Now what are you trying to "read" the TIN with?
    Ernst Engineering
    Fred Ernst, PE
    *Expert Elite*
    01-09-2013 12:59 PM in reply to: fcernst
    Fred, the OP is saying the TIN surface works but a GRID surface doesn't.  The first post in the thread is in regard to the creation of a GRID surface.
    I've never used GRID surfaces, so I can't help, but just trying to define the problem.
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    Valued Mentor
    fcernst
    01-09-2013 01:24 PM in reply to: troma
    Oh thanks.
    Janic,
    Do you want a Grid Surface from a DEM, or do you just want to do this:
    Click Home tabCreate Ground Data panelPoints menuCreate Points - SurfaceOn Grid
    on top of your TIN from that x,yz, file?
    Ernst Engineering
    Fred Ernst, PE
    Active Member
    01-10-2013 12:41 AM in reply to: fcernst
    Again, needs to create a grid of squares on the basis of measurements GPS (data stored in a text file x, y, z) without the TIN.
    my sample data
    1,5644422.129,6423029.854,169.499,
    2,5644411.918,6423153.805,149.853,
    3,5644419.433,6423150.998,149.797,
    4,5644421.052,6423147.883,149.915,
    My email: janic.piotr @ gmail.com
    Regards
    Peter
    Distinguished Contributor
    01-10-2013 02:30 AM in reply to: fcernst
    OP - did you actually try as fcernst suggested?
    this will generate points in a grid pattern that conform to the surface created by your irregular points.
    Civil3D 2013 (infrastructure suite) ANZ
    Self-built i7-3930K, 16Gb RAM, P9X79 m/board
    SSD(system), HDD(data), GTX680, Win7Pro64
