AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Digital Terrain Model (DTM)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Good morning
How to generate a Digital Terrain Model - DTM GRID method in AutoCAD Civil 3D 2012 on the basis of X, Y, Z (saved in. Txt)?
Re: Digital Terrain Model (DTM)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Add as an ENZ point file as Definition data to a new Surface object.
Fred Ernst, PE
C3D 2013 SP1, C3D 2014
W7x64; i7 8gb; Radeon HD 5700
www.ernstengineering.com
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
When adding pops points erroneous reading the information on file with the points.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Well you just can't throw your hands up in the air now
You have to make sure that text file is in the correct format (i.e, comma delimited, space delimited).
Look at the C3D Help to make sure you have the correct format. You may have to do a little post processing to that file in your text editor or Excel.
Fred Ernst, PE
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The file is OK. TIN model comes out correctly. Only after the creation of GRID surface and attempts to read the file with the coordinates of the points of error pops up.
Regards
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi There,
Ok, so we have the TIN surface built as you first requested...
Now what are you trying to "read" the TIN with?
Fred Ernst, PE
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Fred, the OP is saying the TIN surface works but a GRID surface doesn't. The first post in the thread is in regard to the creation of a GRID surface.
I've never used GRID surfaces, so I can't help, but just trying to define the problem.
Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
__________________________________________________________
Credit where credit is due! Give kudos or accept as solution whenever you can.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Oh thanks.
Janic,
Do you want a Grid Surface from a DEM, or do you just want to do this:
Click Home tab
Create Ground Data panel
Points menu
Create Points - Surface
On Grid
on top of your TIN from that x,yz, file?
Fred Ernst, PE
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Again, needs to create a grid of squares on the basis of measurements GPS (data stored in a text file x, y, z) without the TIN.
my sample data
1,5644422.129,6423029.854,169.499,
2,5644411.918,6423153.805,149.853,
3,5644419.433,6423150.998,149.797,
4,5644421.052,6423147.883,149.915,
My email: janic.piotr @ gmail.com
Regards
Peter
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
OP - did you actually try as fcernst suggested?
Click Home tab
Points menu
On Grid
this will generate points in a grid pattern that conform to the surface created by your irregular points.
Self-built i7-3930K, 16Gb RAM, P9X79 m/board
SSD(system), HDD(data), GTX680, Win7Pro64
