• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    Different alignment offsets with the same profile
    120 Views, 2 Replies
    01-10-2013 05:13 PM
    I created a profile for an alignment (which has 2 offsets) and also an assembly with two assembly offsets.
    I wanted to create a corridor where my assembly offsets will have the same profile but will be on different alignments  (alignment offsets).
    In the corridor properties / parameters, I got an error : duplicate profile found.
    Should I copy the profile (for each offset) in different profile views (for each offset) ? Or there is a better way to do that ?
    Thank you.
    Please use plain text.
    Active Member
    Re: Different alignment offsets with the same profile
    01-10-2013 07:03 PM in reply to: dyoxyne
    One more question, the alignment offset has a type : offset (logical) but I can't apply cant to it.
    I changed it to : Rail but I don't think it's a good way.
    Anyone knows ?
    *Expert Elite*
    Adriano_cad
    01-11-2013 09:06 AM in reply to: dyoxyne
    Hello
    To use a project profile on an offset alignment, you need to create the profile of the surface for the alignment offset, and then use the command _AeccSuperimposeProfile to profile the central alignment be used in Offset.
    bye
    Adriano Oliveira
    *Expert Elite*
    MaxiCAD Informática
    www.maxicad.com.br
