• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Expert Elite*
    Re: Different Elvations
    12-13-2012 12:44 PM in reply to: BrianD17
    cogo points would be the spot heights from the survey that you are looking at (probably)
    Where did you get the contours from?
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    Please use plain text.
    Member
    12-13-2012 12:49 PM in reply to: troma
    the contours and the spots were broken out of a survey file.
    *Expert Elite*
    Neilw
    12-13-2012 12:54 PM in reply to: BrianD17
    Just an FYI, in the Civil 3D world when we say a surface was built from survey, many of us take that to mean the survey module was used to create the components of the surface. It is not the same as using points, breaklines and contours from a CAD file to build a surface. So in future posts it would help to make that distinction as the solutions to a problem depends on what method was used.
    Neil Wilson (a.k.a. neilw)
    Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
    WIN 7 64 PRO
    HP Pavillion h8xt, i7 2600, 12 GB
    RADEON 6450, 1 GB
    http://www.sec-landmgt.com
