• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    sboon
    Re: Detention Pond Contours Not Correct
    12-11-2012 02:03 PM in reply to: TRogers
    Another solution would be to add breaklines at the corners from the inside to the outside curve, similar to what the software does with grading objects.  This should force the surface to triangulate better.
    Please use plain text.
    TRogers
    12-11-2012 02:04 PM in reply to: sboon
    Interesting.  I will try this as well.  Thanks Steve.
    If the issue was resolved by this method, please click on "Accept As Solution"
    *Civil 3DJ*
    Todd Rogers
    Visit my blog here.
    New Member
    12-11-2012 02:05 PM in reply to: TRogers
    make the boundary which is the TOB and BOB 3D polyline and then add them as contours and select the swaping edges and unselect the filling gaps in contour data....make the distance .1, angle .001.00000, distance 1 and mid-ordinate .5 and that should work perfect
    TRogers
    12-11-2012 02:09 PM in reply to: drodriguezbp
    That worked like a charm!!
    *Civil 3DJ*
    Todd Rogers
    Visit my blog here.
