• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Expert Elite*
    TRogers
    Accepted Solution
    Detention Pond Contours Not Correct
    241 Views, 13 Replies
    12-11-2012 12:38 PM
    I have 2 feature lines, one is at elevation 132 (TOB), and the other at 123 (TOE).  I inserted elevation points at an increment of every 3 ft., which should make a smooth arc of contours around the pond.  Not the case.  How do I fix the issue I am having?  See pic below...
    If the issue was resolved by this method, please click on "Accept As Solution"
    *Civil 3DJ*
    Todd Rogers
    Visit my blog here.
    Please use plain text.
    Valued Mentor
    LisaPohlmeyer
    Re: Detention Pond Contours Not Correct
    12-11-2012 01:07 PM in reply to: TRogers
    Is your surface set to use a maximum triangle length?
    Lisa Pohlmeyer
    Williamson Co. Dept. of Infrastructure
    Intel i7 3.33Ghz, 16Gb RAM
    Nvidia Quadro 2000D
    C3D 2012 SP3, C3D 2014
    Win 7-64
    Please mark this as the solution if it resolves your issue.
    *Expert Elite*
    sboon
    12-11-2012 01:15 PM in reply to: TRogers
    Switch your surface style to display the TIN lines.  The rules of Delauney triangulation generally force the surface to connect surface points to their nearest neighbours, so in this case you likely have lines running across the inside of your curves, instead of from the inside to the outside featureline.
    *Expert Elite*
    TRogers
    12-11-2012 01:19 PM in reply to: sboon
    *Civil 3DJ*
    Todd Rogers
    Visit my blog here.
    *Expert Elite*
    johnm
    12-11-2012 01:34 PM in reply to: TRogers
    The quick way to fix this is to add them to the surface definition as contours making sure to minimize the flat areas. If you add them as breaklines you will be flippin' all those edges.
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    6 GB RAM, Quadro FX 1700
    *Expert Elite*
    johnm
    12-11-2012 01:36 PM in reply to: johnm
    ... you will have fewer triangles to flip and a better performing surface if you remove all those elev points.
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    *Expert Elite*
    TRogers
    12-11-2012 01:41 PM in reply to: johnm
    It's not allowing me to add the feature lines as contours...
    *Civil 3DJ*
    Todd Rogers
    Visit my blog here.
    *Expert Elite*
    johnm
    12-11-2012 01:52 PM in reply to: TRogers
    Oh that's a bit of a bummer. I do use simple plines for basin & bld pad surfaces quite often. Not the greatest solution but if the basin was disconnected from the rest of the design it may not be a big deal losing the dynamic capabilities.
    The other option is flipping the edges. In both cases I would remove the elv pnts.
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    *Expert Elite*
    johnm
    12-11-2012 01:55 PM in reply to: TRogers
    A grading (I don't like these) or corridor are other options but it does not look like the top and bottom outer curves have the same radius as the offset. The lack of symmetry makes these options tough.
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    *Expert Elite*
    TRogers
    12-11-2012 01:56 PM in reply to: johnm
    I did remove the elevation points.  I exploded the feature lines and added the poly's as contours.  MUCH more control this way.  I will have to remember this workaround.  Thanks for the info!!
    *Civil 3DJ*
    Todd Rogers
    Visit my blog here.
