AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Detention Pond Contours Not Correct
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have 2 feature lines, one is at elevation 132 (TOB), and the other at 123 (TOE). I inserted elevation points at an increment of every 3 ft., which should make a smooth arc of contours around the pond. Not the case. How do I fix the issue I am having? See pic below...
*Civil 3DJ*
Todd Rogers
Visit my blog here.
Re: Detention Pond Contours Not Correct
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Is your surface set to use a maximum triangle length?
Williamson Co. Dept. of Infrastructure
Intel i7 3.33Ghz, 16Gb RAM
Nvidia Quadro 2000D
C3D 2012 SP3, C3D 2014
Win 7-64
Please mark this as the solution if it resolves your issue.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Switch your surface style to display the TIN lines. The rules of Delauney triangulation generally force the surface to connect surface points to their nearest neighbours, so in this case you likely have lines running across the inside of your curves, instead of from the inside to the outside featureline.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
*Civil 3DJ*
Todd Rogers
Visit my blog here.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The quick way to fix this is to add them to the surface definition as contours making sure to minimize the flat areas. If you add them as breaklines you will be flippin' all those edges.
C3D 2012, RD 2012
Win 7 64, Core i7,
6 GB RAM, Quadro FX 1700
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
... you will have fewer triangles to flip and a better performing surface if you remove all those elev points.
C3D 2012, RD 2012
Win 7 64, Core i7,
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
It's not allowing me to add the feature lines as contours...
*Civil 3DJ*
Todd Rogers
Visit my blog here.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Oh that's a bit of a bummer. I do use simple plines for basin & bld pad surfaces quite often. Not the greatest solution but if the basin was disconnected from the rest of the design it may not be a big deal losing the dynamic capabilities.
The other option is flipping the edges. In both cases I would remove the elv pnts.
C3D 2012, RD 2012
Win 7 64, Core i7,
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
A grading (I don't like these) or corridor are other options but it does not look like the top and bottom outer curves have the same radius as the offset. The lack of symmetry makes these options tough.
C3D 2012, RD 2012
Win 7 64, Core i7,
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I did remove the elevation points. I exploded the feature lines and added the poly's as contours. MUCH more control this way. I will have to remember this workaround. Thanks for the info!!
*Civil 3DJ*
Todd Rogers
Visit my blog here.
