• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Breslin, Kevin
    Detaching a drawing from a Project
    101 Views, 3 Replies
    10-05-2003 11:12 PM
    I cannot seem to detach drawings from a project. The directions state:
    To detach a drawing from a project
    1.. In Toolspace, on the Prospector tab, right-click the drawing you want
    to detach.
    2.. On the shortcut menu, click Detach Project.
    This does not work. The only options I have are "Open" and "Refresh". I've
    tried from within a drawing in the project and drawings from outside the
    project and in both cases it does not give me the "Detach Project" option.
    Kevin Breslin
    Please use plain text.
    *Philbrick, Daniel
    Re: Detaching a drawing from a Project
    10-06-2003 10:12 PM in reply to: *Breslin, Kevin
    Kevin,
    After you create a project, you can attached a saved drawing to the project.
    If you select the Master View in Prospector, you can see the drawings that
    are attached to that project. You can open the selected drawing by either
    directly opening the drawing or by selecting the drawing from the Project
    drawing collection, rt . click, and open. It looks like if you open it
    using the second method, the "Detach" option is not on the right click menu.
    If you browse to the file and open it, the menu is correct. I will log
    this issue.
    thanks,
    Dan Philbrick
    Autodesk, Inc.
    "Kevin Breslin" wrote in message
    news:A4D2DE962E12700377827A08982AA809@in.WebX.maYIadrTaRb...
    want
    > to detach.
    I've
    > Kevin Breslin
    *Sanders, Henry
    10-06-2003 10:21 PM in reply to: *Breslin, Kevin
    Kevin,
    The Detach Drawing option is only available for drawings located under the
    Open Drawings collection, not at the Projects Drawing collection.
    Henry
    want
    > to detach.
    I've
    > Kevin Breslin
    *Todd, Rob
    Re:
    11-05-2003 05:17 AM in reply to: *Breslin, Kevin
    The Detach Drawing command that can only be used on the "Active" drawing
    session (assuming that the "Active" drawing session is attached to a
    project).
    "Henry Sanders" wrote in message
    news:2E6E78B859464352C908D58BF67E3952@in.WebX.maYIadrTaRb...
    > Kevin,
    > Henry
    > want
    > > to detach.
    > I've
    option.
    > > Kevin Breslin
