AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Descriptio n key code for all points not matching any other codes?
- Highlight
- Email to a Friend
- Report Inappropriate Content
We are using Civil 3d 2010.
In a description key code file, I would assume that a description key code of simply * would capture all points, but it seems this code gets ignored. How do we create a key code that captures all points?
For example, if I want to take advantage of the hierarchical processing of DKC files to assign layers, point styles, label styles, etc, I can theoretically create a 'design' DKC file that makes all points, regardless of their desciptions, to be sized relatively, and then move that DKC file to the top of the DKC file list.
I know this can be accomplished through the "_all points" point group, but I want to be able to control point layers as well, and as far as I know, neither point groups, point styles, nor label styles affect the insertion layer of a point, but DKC files do.
Andrew
Re: Descriptio n key code for all points not matching any other codes?
- Highlight
- Email to a Friend
Good question I'd like to know also.
- Highlight
- Email to a Friend
If I remember correctly this is actually an old bug. A Desc Key of * doesn't seem to work. What you can do instead is set a filter that includes everything except a nonsense code.
Try a Key with a code like "~xyz" The tilde character means match anything except for the code xyz, so it should apply to everything else.
Another thing to consider is that point descriptions which don't match anything in the DescKey will fall to the default point settings. In our template we have a default for point style, label style and point layer so that points with bad descriptions end up with those settings.
- Highlight
- Email to a Friend
We have a description key set that we use to catch non standard codes that are not picked up by our survey code keyset.
The code we have that catches all codes is ~?
We assign a label style and point style that highlights that the point has an unrecognised code.
Andrew Puller
Maitland, NSW, Australia
Windows 7 Enterprise 64bit
Intel core i7 2600 @ 3.40 GHz with 16GB Ram
Civil 3d 2013 64bit
- Highlight
- Email to a Friend
Thanks. The ~ character worked great.
