AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Descriptio n Keys Settings
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
For some reason in my base template for field work the
"Diasble Description Keys" option in Points Creation is set to "true"
How can make this default to "False" in my template.
I've tried changing it and then saving the template again but it reverts to true
all of the time. This is irratiting because I have
to select my points and do applydesckeys whenever I import points.
Bo
Re: Descriptio n Keys Settings
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Open the DWT file, go to the Settings tab of Toolspace, expand Points, expand Commands, dbl click CreatePoints, change the setting here. If you were changing setting under the PointCreation dialog, those settings are normally only used during the tie that dialog is open.
If this isn' working, then you'd better verify that the correct dwt is being used for starting new drawings.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Ahh!!! Thats where it is!!!
Thanks!!!
