• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Contributor
    bo.martin
    Accepted Solution
    Description Keys Settings
    114 Views, 2 Replies
    05-05-2012 10:15 AM
    For some reason in my base template for field work the
    "Diasble Description Keys" option in Points  Creation is set to "true"
    How can make this default to "False" in my template.
    I've tried changing it and then saving the template again but it reverts to true
    all of the time. This is irratiting because I have
    to select my points and do applydesckeys whenever I import points.
    Bo
    Please use plain text.
    *Expert Elite*
    Re: Description Keys Settings
    05-05-2012 12:18 PM in reply to: bo.martin
    Open the DWT file, go to the Settings tab of Toolspace, expand Points, expand Commands, dbl click CreatePoints, change the setting here. If you were changing setting under the PointCreation dialog, those settings are normally only used during the tie that dialog is open.
    If this isn' working, then you'd better verify that the correct dwt is being used for starting new drawings.
    Valued Contributor
    bo.martin
    05-05-2012 12:57 PM in reply to: Jeff_M
    Ahh!!! Thats where it is!!!
    Thanks!!!
