• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    tm
    Member
    Delete key doesn't work, Can't edit text
    3854 Views, 9 Replies
    03-04-2009 04:11 PM
    Any ideas? I have to go up to cut and select the object to delete. Also when I click on text the edit dialogue box doesn't come up. I have to go to properties to edit.
    Please use plain text.
    *Jeff Mishler
    Re: Delete key doesn't work, Can't edit text
    03-04-2009 04:21 PM in reply to: tm
    Make sure the Pickfirst system variable is set to
    1
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    Any
    properties to edit.
    tm
    Member
    03-04-2009 05:12 PM in reply to: tm
    Thanks Jeff your awesome!
    Member
    04-28-2009 09:18 AM in reply to: tm
    I have had the same problem a couple of times already and the only way to remedy the situation is to completely uninstall and re-install Civil3D. My Problem started with not being able to edit text, then not being able to use the delete key, and then the right click options pop-up box becomes unusable. I have re-installed Civil 3D for the third time and now my text editing by double clicking the text is not working. Can anyone help on this before I have to re-install for a forth time???
    Member
    tm
    Member
    04-28-2009 01:29 PM in reply to: tm
    Check out Jeff's reply on my post. This worked like a charm for me. I have not had the problem again.
    Member
    04-28-2009 01:37 PM in reply to: tm
    I tried that PICKFIRST command which didn't work for the text editing but the DBLCLKEDIT command worked for that. I still can't figure out why the right click properties is not working, but i am on the hunt
    New Member
    12-01-2012 03:41 AM in reply to: stiedemann
    try "audit" and fix all, i think it will be usefull, i ahd same problem before
    Member
    01-24-2013 02:54 AM in reply to: tm
    PickFirst worked for me very well :smileyhappy: thx
    Member
    meihum
    05-10-2013 02:14 AM in reply to: amgedgoga
    audit worked for me - cheers
