• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Expert Elite*
    Neilw
    Accepted Solution
    Delete all labels on a Feature Line
    237 Views, 11 Replies
    01-31-2013 08:20 PM
    Can anyone offer suggestions on how to delete all labels on a featureline? Ideally it would be great if we could just pick the line and have it's labels deleted. QSelect and Select Similar require too much interaction to be convenient.
    Neil Wilson (a.k.a. neilw)
    Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
    WIN 7 64 PRO
    HP Pavillion h8xt, i7 2600, 12 GB
    RADEON 6450, 1 GB
    http://www.sec-landmgt.com
    Please use plain text.
    *Expert Elite*
    Re: Delete all labels on a Feature Line
    02-01-2013 06:03 AM in reply to: Neilw
    What happens if you delete the feature line and OOPS it back?  I haven't tried it.
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    *Expert Elite*
    Neilw
    02-01-2013 09:42 AM in reply to: troma
    That's not good If the featureline is used for a grading or is a breakline in a surface. I expect this will require a custom tool. I wonder if anyone has developed one.
    WIN 7 64 PRO
    RADEON 6450, 1 GB
    *Expert Elite*
    johnm
    02-01-2013 12:03 PM in reply to: Neilw
    One way is to select the FL and temporarily move it to an empty layer. Select the line and on label on the line. Isolate these two layers.
    At first you will see all the labels on the same layer. Regen the display and only the labels on the FL are visible. Use L to R crossing windows to select the labels and erase.
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    6 GB RAM, Quadro FX 1700
    *Expert Elite*
    02-01-2013 02:02 PM in reply to: Neilw
    I have now....don't forget to Unblock the zip file before extracting the dll. Use NETLOAD to load it into C3D, command name is REMOVELABELS. May work on many of the C3D labeled objects, tested on Featurelines and Surfaces. No warranty on what will happen if you select something else :-) I will do some more extensive testing at a later date, or, if someone wants to do so, I will provide the source code.
    This is for C3D2013+ only.
    Jeff_M, also a frequent Swamper
    *Expert Elite*
    Neilw
    02-01-2013 03:24 PM in reply to: Jeff_M
    Wow...that is really slick! It even warns you if there are no labels in the file that can be deleted.
    What a handy tool. Nice job Jeff and thank you!
    PS: Considering the name of the .dll, are there other commands included?
    Follow up: I tried it on a surface thinking it would remove contour labels. It didn't, but I was surpised to find it had deleted all the spot elevation and slope labels. Better watch out with that one.
    WIN 7 64 PRO
    RADEON 6450, 1 GB
    *Expert Elite*
    02-01-2013 04:20 PM in reply to: Neilw
    Thanks, Neil. I named the DLL thinking I may be throwing some quick little commands in there. Some I've posted in the past, and others I may see fit to add in the future. So it's more of a forward thinking name than meaning anything today.
    Yes, selecting a surface will remove all of it's associated labels. I will have to see about the contour labels, I think these are of a different object type (a label group vs a label).
    *Expert Elite*
    johnm
    02-01-2013 05:02 PM in reply to: Neilw
    Very cool Jeff! Thanks a bunch.
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    *Expert Elite*
    Neilw
    02-01-2013 06:19 PM in reply to: Jeff_M
    I can't think of any scenario where I would want to globally delete all spot and slope labels, but deleting contour labels would come in handy in those cases where we have a bazillion little contour label lines scattered about.
    By the way, a while back you made a tool to toggle off all masks in label styles. It is very useful when exporting to older versions of Autocad since the C3D export tool leaves them intact and makes a mess for the end user to clean up. That would be a good one to add to your tool set if you get around to building one.
    You might consider making your tools available on the ACAD App. exchange. They're definitely worth a small fee.
    WIN 7 64 PRO
    RADEON 6450, 1 GB
    *Expert Elite*
    Joe-Bouza
    02-03-2013 07:50 AM in reply to: Neilw
    select similar doesn't work for that?
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
