• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    yasin2ray
    Accepted Solution
    Defpoints layer not selectable
    1161 Views, 11 Replies
    05-09-2012 02:54 PM
    I just drew a polyline on my defpoints layer, but now the polyline is not selectable. I have had this happen before with a different file and couldn't fix it then either.
    All the settings/layer states look fine, but as soon as I add something to the defpoints layer it's untouchable.
    Not an urgent question, but definately something I need to figure out since it keeps happening to me!
    Thanks!
    a
    AutoCAD Civil 3D 2010
    Please use plain text.
    dsigman
    Re: Defpoints layer not selectable
    05-09-2012 03:18 PM in reply to: yasin2ray
    Try turning on layer 0. Should fix the problem.
    *Expert Elite*
    BrianHailey
    05-09-2012 05:45 PM in reply to: yasin2ray
    A better solution would be to not use defpoints. Why are you using defpoints? Most likely because it won't plot. In the last several releases you can set any layer to not plot and so the use of defpoints is no longer needed. Why do I recommend you don't use defpoints? Well, you already found one. The other reason, if you were to shelve this drawing for 6 months and then come back to it. All that stuff that's on the defpoints layer, why is it there? You probably will forget but, if you have a layer set to not plot called, "notes to drafters", then you know what that stuff is.
    Just my thoughts on the subject.
    dsigman
    05-10-2012 09:25 AM in reply to: BrianHailey
    That's how i've been handling it for years. I have a no-plot layer for my survey calc's and one for surveyor's notes. Occasionally I'll use defpoints to make a hatch boundary. I suppose I could add a no-plot layer for hatching but it's easy enough to use defpoints. I never touch layer 0 so it's not a problem.
    Valued Mentor
    owenmull
    05-10-2012 02:37 PM in reply to: dsigman
    And the Cad Guru said unto his minions, "Thou shalt not use DEFPOINTS!"
    -Owen
    Windows 7 x 64 bit
    ATI FirePro V4800 Triple Monitor
    12 GB RAM
    Intel Xeon W3550 @ 3.07 GHz
    Civil 3D 2012 SP 2
    ______________________________________________________________
    Intel inside. Idiot outside.
    Usually, I find that the problem is between the keyboard and the chair.
    yasin2ray
    05-11-2012 11:11 AM in reply to: BrianHailey
    Cad people... always cracking me up. Thanks for a little humor with this one while I'm not having a total breakdown.
    I tried turning on the 0 layer, but Defpoints still misbehaved a bit (invisible or visible but untouchable).
    I'll go with the suggestion to make my own "no plot" layer and turn on the 'no plot' setting.
    Thanks ya'll!
    Member
    01-05-2013 06:31 AM in reply to: yasin2ray
    I just had this problem. Turning on Layer 0 in the model didn't help, BUT if you open the Layer Properties Manager, right click on Layer 0 and select VP Thaw Layer in All Viewports, this does it. Seems if Layer 0 is frozen in your layouts, it locks the Defpoint layer in the model.  Go figure.
    I use the Defpoints layer all the time and it's not usually a problem.  I use it to create grids to lay out elevations, create insertion points for blocks, etc. :smileyhappy:
    *Expert Elite*
    01-06-2013 07:46 AM in reply to: BrianHailey
    Hey Brian:
    As you know, I am older and probably more set in my ways than you.  Just wap me with a wet noodle the next time you see me.  I have been using defpoints since day one with no problems as far as I know.
    I can't help it.
    :smileyhappy:
    Bill
    *Expert Elite*
    BrianHailey
    01-06-2013 08:25 AM in reply to: wfberry
    "With great age comes great stubborness"
    I'm just waiting for the next replacement for C3D comes out and then I'll be all like, "Well in Civil 3D you did it this way. How come I can't do it that way in this new software?"
    Distinguished Contributor
    sadekcivil
    01-06-2013 12:42 PM in reply to: yasin2ray
    you can edit the layer name and change it from defpoints to defpointse as an example and put select your object and do what you like to do and eventually rename the depoints layer to the default name to use it again
    Thank you.
    Sadek
    Please do not forget approve as solutions and Points
    to Remember Please Accept as Solution and Kudos Please
