• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Contributor
    Re: Dealing with AECC_COGO_POINTs
    10-31-2012 04:48 PM in reply to: J_Seeds
    To get around that, I went in and created a special text style the is annotative at 1"=1'.  I created mine at 0.06' (Leroy 60).
    Tne when the points are inserted at 1"=1', they come in corrrectly.  Since the text type is annotative, the size will automatically rescale to Leroy 60.  So you can change the scale and the points and symbols will re-scale.
    Surveyor Lee
    Please use plain text.
    *Expert Elite*
    AllenJessup
    11-01-2012 05:49 AM in reply to: J_Seeds
    You might be able to handle it using an expression the way I handle the text height. See my post [Here].
    Allen
    *Expert Elite*
    11-01-2012 07:38 AM in reply to: AllenJessup
    That looks familiar!  :smileywink:
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    *Expert Elite*
    AllenJessup
    11-01-2012 07:44 AM in reply to: troma
    Yes. I knew it had been mentioned.:smileyhappy: But sometimes a second opinion, although exactly the same, will help someone along the right track.:smileywink:
    Allen
    *Expert Elite*
    11-01-2012 08:17 AM in reply to: AllenJessup
    Fair 'nuf.  Nice theory. :smileywink:
    *Expert Elite*
    AllenJessup
    11-01-2012 08:22 AM in reply to: troma
    troma wrote:
    Nice theory
    And I'm standing buy it! Truly I did remember that it had been mentioned. But I only reread the original post. So I hadn't remembered you'd covered it in full detail.
    Redundancy never hurts. Belt and suspenders and all that. How many people here in the North East wish they had a redundant power supply!
    Allen
    *Expert Elite*
    11-01-2012 09:26 AM in reply to: AllenJessup
    Truly, tautology is so redundant!
    The 'nice theory' I was referring to is that repetition will actually persuade someone to pay attention; not that you knew you were repeating. I believe you.
    J_Seeds
    11-01-2012 09:53 AM in reply to: troma
    Allen, I tried your expression solution and it does what I want when the point label is in its "home position" however I'm not able to apply the expression to the text height in dragged state mode. Am I missing something? BTW I'm working in 2010 not sure if 2012 or 13 is different.
    *Expert Elite*
    11-01-2012 10:14 AM in reply to: J_Seeds
    Can you set the dragged state to 'As Composed' ?
    *Expert Elite*
    AllenJessup
    11-01-2012 10:15 AM in reply to: J_Seeds
    In the Label Style Composer, on the Dragged State tab, under Dragged State Components the Display must be As Composed not Stacked Text. You can't put in an expression for text height in the stacked text.
    Allen
