• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Employee
    Re: Daylight to offset with maximum slope
    11-08-2012 10:56 AM in reply to: sboon
    Well I applaud the creative use of conditionals and generic links, take a look at the PKT file that I posted. The logic inside it is pretty straight forward and should be a good starting point for a solution.
    Cheers,
    Peter Funk
    Peter Funk
    Please use plain text.
    Member
    11-08-2012 11:23 AM in reply to: peterfunkautodesk
    I imported the .pkt file as a subassembly and it seem to import fine, it gave it a "tool pallete button" with the associated name and such. However there where no parameters to adjust inside, it appeared to be an "empty shell".  Furthermore, using it produced and error
     [DaylightWithClearZone was created with Subassembly Composer, please visit Autodesk website (http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334440&linkID=9240698) to download the enabler extension.]  (Source: DaylightWithClearZon
    Looks like i need to download an extension. I will try to find what i need at the website.
    Employee
    11-08-2012 11:39 AM in reply to: DenverDave
    I made that with the 2012 Subassembly Composer. It doesn't have any parameters for adjusting the offset etc, but those could be added.
    Peter Funk
    Peter Funk
    Distinguished Contributor
    sadekcivil
    12-31-2012 11:04 AM in reply to: peterfunkautodesk
    can you upload your subassembly because the page didn't found
    Please do not forget approve as solutions and Points
    to Remember Please Accept as Solution and Kudos Please
    01-01-2013 05:39 AM in reply to: sadekcivil
    Sadek:
    It was a download and should have been downloaded to your browser's download directory (folder).
    Bill
    sadekcivil
    01-01-2013 06:20 AM in reply to: wfberry
    Bill
    See attached file, that is what i got
