• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Daylight points list
    26 Views, 0 Replies
    09-12-2005 06:25 AM
    Hi
    I would like to produce a list showing, for each section, the northing,
    easting and elevation of the daylight points (and other codes). I used the
    corridor > export corridor points as cogo points and then generated a report
    using the "Point List" form. However, that report doesn't show the
    correspondence between the points and the section (number or pk) they were
    extracted from.
    In short, I need an extra column in the following table reporting the
    section number. Is there an easy way to do this?
    Number
    Northing (m)
    Easting (m)
    Elevation (m)
    Description
    1
    8580.900
    19836.292
    558.755
    Daylight
    2
    8605.819
    19838.309
    562.842
    Daylight
    3
    8626.848
    19838.750
    565.647
    Daylight
    4
    8630.852
    19838.796
    566.153
    Daylight
    61
    8580.900
    19836.292
    558.755
    Daylight_Cut
    62
    8605.819
    19838.309
    562.842
    Daylight_Cut
    98
    8778.774
    19822.926
    572.325
    Daylight_Fill
    99
    8784.323
    19825.429
    572.638
    Daylight_Fill
    Thank you
    Luis Vasconcelos
    PORTUGAL
    Please use plain text.
