AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Data Shortcuts
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I've just used Data Shortcuts for the first time but I've found that I can only reference in Surfaces and Alignments. Is this correct? The file I am creating my model in, has Corridors/Feature Lines/Gradings as well but I can't create Data Shortcuts for these? or am I missing something?
Re: Data Shortcuts
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
No, you're not missing anything. I believe the intent is that you use those features to create surfaces, which you can dref. You can also xref the corridor into a drawing, dref the alignment and create sample lines for cross sections. Be sure not to put all your civil 3D objects in one drawing. Keeping the data separate will help in the case of corruption.
Williamson Co. Dept. of Infrastructure
Intel i7 3.33Ghz, 16Gb RAM
Nvidia Quadro 2000D
C3D 2012 SP3, C3D 2014
Win 7-64
Please mark this as the solution if it resolves your issue.
Re: Data Shortcuts
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
In the Prospector tab in Toolspace, under Data Shortcuts at the bottom, you will see that only Surfaces, Alignments, Pipe Networks, and View Frame Groups can be Data Shortcuts.
Re: Data Shortcuts
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for the advice. I had been hoping that I could just dref into a drawing the components of the model without needing to xref the whole model drawing. By xreffing in the whole model drawing then I don't see the benefit of using the drefs in the first place?
Re: Data Shortcuts
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Xreffing allows you to see, for example, the contours of a surface built in another base drawing, as well as label the contours. However, xreffing does not allow you to use the surface in profile views, or to do volume calculations, to name a few things that require data referencing the object.
Same with other objects: an xref'd alignment lets you see the alignment, but does not allow you to label it or reference it in the drawing in any way. For this you need data references.
Re: Data Shortcuts
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
castled071049 wrote:Xreffing allows you to see, for example, the contours of a surface built in another base drawing, as well as label the contours. However, xreffing does not allow you to use the surface in profile views, or to do volume calculations, to name a few things that require data referencing the object.
I believe that Xref'd civil objects can be labelled e.g. surfaces & alignments
(No connection with Autodesk other than using the products in the world)
IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
Re: Data Shortcuts
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yes, as I said, labeling is possible with xrefs. But you cannot use xref'd C3D objects for other purposes: e.g. surfaces for volume calculations, or referencing an alignment in a station/offset label, to name a couple of things.
Re: Data Shortcuts
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Re: Data Shortcuts
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yes, there are certain (but not all) labels that can be added to xref'd C3D objects. My point was to show the OP why data shortcuts are sometimes more useful than an xref. There are many things you can't do with an xref'd C3D object that you can with a dref'd object. He was wondering what the purpose of data shortcuts was.
I do stand corrected, however, on adding station/offset labels to xref'd alignments. I did not know this would work, but it does. I learned something new today.
Re: Data Shortcuts
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
No worries - I use this technique to produce my plotted sheets i.e. Xref the engineering drawings and label the Xref.
The technique also works well for surfaces e.g. contour labels, slope labels etc etc
