• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    New Member
    Data Shortcuts
    245 Views, 9 Replies
    10-31-2012 03:25 AM
    I've just used Data Shortcuts for the first time but I've found that I can only reference in Surfaces and Alignments.  Is this correct? The file I am creating my model in, has Corridors/Feature Lines/Gradings as well but I can't create Data Shortcuts for these? or am I missing something?
    Please use plain text.
    Valued Mentor
    LisaPohlmeyer
    Re: Data Shortcuts
    10-31-2012 05:36 AM in reply to: simon
    No, you're not missing anything.  I believe the intent is that you use those features to create surfaces, which you can dref. You can also xref the corridor into a drawing, dref the alignment and create sample lines for cross sections.  Be sure not to put all your civil 3D objects in one drawing.  Keeping the data separate will help in the case of corruption.
    Lisa Pohlmeyer
    Williamson Co. Dept. of Infrastructure
    Intel i7 3.33Ghz, 16Gb RAM
    Nvidia Quadro 2000D
    C3D 2012 SP3, C3D 2014
    Win 7-64
    Please mark this as the solution if it resolves your issue.
    Valued Mentor
    Re: Data Shortcuts
    10-31-2012 06:10 AM in reply to: simon
    In the Prospector tab in Toolspace, under Data Shortcuts at the bottom, you will see that only Surfaces, Alignments, Pipe Networks, and View Frame Groups can be Data Shortcuts.
    New Member
    Re: Data Shortcuts
    10-31-2012 06:50 AM in reply to: simon
    Thanks for the advice. I had been hoping that I could just dref into a drawing the components of the model without needing to xref the whole model drawing.  By xreffing in the whole model drawing then I don't see the benefit of using the drefs in the first place?
    Valued Mentor
    Re: Data Shortcuts
    10-31-2012 07:03 AM in reply to: simon
    Xreffing allows you to see, for example, the contours of a surface built in another base drawing, as well as label the contours. However, xreffing does not allow you to use the surface in profile views, or to do volume calculations, to name a few things that require data referencing the object.
    Same with other objects: an xref'd alignment lets you see the alignment, but does not allow you to label it or reference it in the drawing in any way. For this you need data references.
    neilyj
    Re: Data Shortcuts
    10-31-2012 07:55 AM in reply to: castled071049
    I believe that Xref'd civil objects can be labelled e.g. surfaces & alignments
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014, Civil 3D 2013 (UKIE) Hotfix 3; Win 7 Pro x64
    256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    Valued Mentor
    Re: Data Shortcuts
    10-31-2012 07:58 AM in reply to: neilyj
    Yes, as I said, labeling is possible with xrefs. But you cannot use xref'd C3D objects for other purposes: e.g. surfaces for volume calculations, or referencing an alignment in a station/offset label, to name a couple of things.
    neilyj
    Re: Data Shortcuts
    10-31-2012 08:01 AM in reply to: castled071049
    neilyj
    Valued Mentor
    Re: Data Shortcuts
    10-31-2012 08:08 AM in reply to: neilyj
    Yes, there are certain (but not all) labels that can be added to xref'd C3D objects. My point was to show the OP why data shortcuts are sometimes more useful than an xref. There are many things you can't do with an xref'd C3D object that you can with a dref'd object. He was wondering what the purpose of data shortcuts was.
    I do stand corrected, however, on adding station/offset labels to xref'd alignments. I did not know this would work, but it does. I learned something new today.
    neilyj
    Re: Data Shortcuts
    10-31-2012 08:55 AM in reply to: castled071049
    No worries - I use this technique to produce my plotted sheets i.e. Xref the engineering drawings and label the Xref.
    The technique also works well for surfaces e.g. contour labels, slope labels etc etc
    neilyj
