• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    New Member
    Re: Data Shortcut Error 2011.
    09-01-2012 04:03 PM in reply to: mikeevans
    Dude
     I had the same error... types SHORTCUTASSOCIATEDISABLE in command line and problem solved!!!!
    Please use plain text.
    Member
    09-04-2012 01:40 PM in reply to: rogelio_castro_fierros
    I am also having the same problem with the data shorcuts (Civil 3D 2013). I have tried the suggestions posted so far, but no luck. Any help would be appreciated.
    Active Member
    11-28-2012 02:50 PM in reply to: mikeevans
    I have the same problem using 2012 in that i would repeatedly get the error message requiring the dwg to be saved. I found that i couldnt create data shortcuts as my alignment was already linked to something in the dwg, In my case a profile & corridor. Once i deleted the corridor that it was linked to i could immediately create shortcuts.
    12-19-2012 11:24 PM in reply to: josh.bonora
    It appears to have something to do with corridors and it's state when a save happens. Locking the layer the corridor is on appears to prevent the corridor from changing it's state based on the save action.
    Civil Reminders
    http://blog.civil3dreminders.com/
    http://www.CivilReminders.com/
    New Member
    12-28-2012 06:40 AM in reply to: mikeevans
    I'd experienced this error using Civil3D 2013.  Previously my 'File Save' >> 'Save as:' Setting was set to AutoCAD 2010 (*.dwg).  Whoever suggested problems with backwards compatibility was right, in my case.  I changed this setting to AutoCAD 2013 (*.dwg) to match the year of the version I have and then I was able to create data shortcuts.  I hate to forfeit compatibility for this though.
