• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    dla4y4
    Data Refence Surface dissapears
    78 Views, 2 Replies
    02-21-2013 06:49 AM
    I have a Surface that is data referenced into many different drawings. On one of the drawings, the reference will not show contours until I sync. It will show the boundary. Just one of them...but I can't use sheet set manager to publish drawings since I have to open it up and sync. Has anybody encountered this before? Is there a setting we changed? The styles are all the same. The surface is on C-Surface, the boundary is on C-Surface, the Contours are on C-Surface-MJR, C-Surface-MNR.
    Dan
    Please use plain text.
    Re: Data Refence Surface dissapears
    02-21-2013 10:36 AM in reply to: dla4y4
    What if you detach the reference, save and close the drawing, re-open the drawing, re-attach the data ref? Does that make it behave?
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    02-22-2013 08:22 AM in reply to: dla4y4
    You could make the program automatically reload references when drawings are opened.  Add the following LISP command to the acaddoc.lsp file:
    (command "SynchronizeReferences")
    If you only need this to occur for one project only, save this copy of the acaddoc.lsp in the same folder as the drawings that are being published.
    David Zavislan, P.E. | CAD Manager / Associate | NV5 | www.nv5.com
