• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    johng0927
    DIMENSIONS & BEARINGS
    215 Views, 2 Replies
    10-25-2012 12:21 PM
    I draw property plats for a surveyor and looking for a way to add the bearings (for example: N 56 15' 32" E) along the property lines.  Right now, I use the Distance command to find out the bearing, write it down, and then add it to the aligned linear dimension text.  I'm guessing there's a faster way to get a bearing along with the distance without typing it in.  Thanks
    Please use plain text.
    *Expert Elite*
    AllenJessup
    Re: DIMENSIONS & BEARINGS
    10-25-2012 01:41 PM in reply to: johng0927
    Start with the Labels and Tables Tutorials.  Then add a single segment label with a style that shows bearing and distance.
    I know this sound short. But if you're not familiar with Labels and Label Styles. It would take pages to type out all you need to know.
    Allen
    Valued Mentor
    owenmull
    10-26-2012 09:31 AM in reply to: johng0927
    Attached is a video demonstrating how to label a line with Bearing & Distance.
    (Simply change the extension from .txt to .swf and open with Windows Media Player or your web browser)
    -Owen
    Windows 7 x 64 bit
    ATI FirePro V4800 Triple Monitor
    12 GB RAM
    Intel Xeon W3550 @ 3.07 GHz
    Civil 3D 2012 SP 2
    ______________________________________________________________
    Intel inside. Idiot outside.
    Usually, I find that the problem is between the keyboard and the chair.
