• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Civil 3D
    Active Contributor
    Accepted Solution
    DEM file
    290 Views, 9 Replies
    11-08-2012 08:50 AM
    I have a DEM file, (or that is what I have been led to believe) it is in space delimited txt format. It contains breakline and point data. Every time I try and add it to a surface I get an invalid DEM file error. Can anyone give me a hint as to why and how I can correct this. I am using Civil 3D 2013.
    Please use plain text.
    *Expert Elite*
    TRogers
    Re: DEM file
    11-08-2012 09:21 AM in reply to: bandit1965
    A lot of the entities out there have changed there file format for there DEM's and they don't work in Civil 3D anymore.  TNRIS is one of these entities.  I use Global Mapper to fix the file and export it back out as a DEM.  If it's not too large, you can email it to trogers@tcadsys.com and I will fix it for you.
    If the issue was resolved by this method, please click on "Accept As Solution"
    *Civil 3DJ*
    Todd Rogers
    Visit my blog here.
    Active Contributor
    Re: DEM file
    11-08-2012 09:34 AM in reply to: bandit1965
    I have shipped it to you, work your magic.
    *Expert Elite*
    TRogers
    Re: DEM file
    11-08-2012 09:39 AM in reply to: bandit1965
    Ok.  I didn't read this very well the first go round, and apologies for that.  You need to import this as points, not attach it to surface as a DEM.  It looks like the point file format is PENZD.  Then add the Point Group _All points to the surface.  Works fine.
    *Civil 3DJ*
    Todd Rogers
    Visit my blog here.
    *Expert Elite*
    BrianHailey
    Re: DEM file
    11-08-2012 04:33 PM in reply to: TRogers
    If the file is very large, dont' import it into Civil 3D as points, just add it directly to the surface as a point file. Works much better that way for very large data sets.
    Obviously, since Todd recommended importing it as a points and then using adding it to the surface as a point group, this particular file probably isn't very large, but it's good for others to know about if they didn't already.
    Is it just me or do I sound like I'm babbling?
    *Expert Elite*
    TRogers
    Re: DEM file
    11-12-2012 06:36 AM in reply to: BrianHailey
    It was fairly small and came in easily. Sent from my Verizon Wireless 4G LTE Smartphone
    *Civil 3DJ*
    Todd Rogers
    Visit my blog here.
    *Expert Elite*
    johnm
    Re: DEM file
    11-12-2012 07:17 AM in reply to: BrianHailey
    You're not babbling. :smileyhappy:
    I just see you providing an important public service announcment. That is a very important tip for large data sets.
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    6 GB RAM, Quadro FX 1700
    Active Contributor
    Re: DEM file
    11-14-2012 07:38 AM in reply to: TRogers
    Thanks for the help, evertyhing is working great. I made that a lot harder than it seemed.
    *Expert Elite*
    BrianHailey
    Re: DEM file
    11-14-2012 01:43 PM in reply to: bandit1965
    What did you do to get the data into the surface? Import points? Point group? Add point file? Enquiring minds want to know.
    *Expert Elite*
    TRogers
    Re: DEM file
    11-14-2012 01:49 PM in reply to: BrianHailey
    It was a rather small file, so just a basic import of the points using PENZD did the trick.  The file had an extension of points.dem.txt.  So it was really just an ASCII file, not a DEM file.
    I gave you props on my blog about the double click addition :smileywink:
    http://civil3dj.wordpress.com/
    *Civil 3DJ*
    Todd Rogers
    Visit my blog here.
