• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    Cut and fill to specific elevation (BFE)- For FP Mitigation
    118 Views, 2 Replies
    01-29-2013 07:57 AM
    I need to figure out the amount of cut and fill up to a specific elevation, the Base Flood Elevation.  Right now, I am creating the proposed and existing surfaces in Civil 3D and making a fellow coworker convert it to Eagle Point to generate this slice Volume Table. See attached PDF.  Is there a way to generate this type of table in Civil 3D? Any ideas?  Thank you!
    Please use plain text.
    TRogers
    Re: Cut and fill to specific elevation (BFE)- For FP Mitigation
    01-29-2013 09:41 AM in reply to: amybrammer10
    Is this what you're looking for?...
    This can be exported out to a TXT file.
    If the issue was resolved by this method, please click on "Accept As Solution"
    *Civil 3DJ*
    Todd Rogers
    Visit my blog here.
    Valued Contributor
    01-29-2013 10:44 AM in reply to: amybrammer10
    Another option is to set a user contour to your required elevation.  Extract the contour as a polyline and use it/them as a boundary.  Even if the boundary is only temporary.
    You may have to edit them a bit to get the desired results.
    Conan Witzel
