• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Expert Elite*
    Curved subassembly issue
    100 Views, 2 Replies
    03-07-2013 01:38 PM
    I am trying to create a subassembly with a curve in it. See attached .pkt and .dwg files. Very small and simple.
    When I attach the Subassembly to the Assembly, the event viewer shows "[Something wrong with current subassembly: The given key was not present in the dictionary.]  (Source: Subassembly.Subassembly1)"
    The link that represents the curve does not display; only the tesselated points display. In the Subassembly Composer the curve does display.
    The file called curved.zip needs to be renamed to curved.pkt. This forum does not allow attachment of files with pkt extension (doh!)
    Any help will be appreciated,
    Tim
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    Please use plain text.
    *Expert Elite*
    Re: Curved subassembly issue
    03-07-2013 03:15 PM in reply to: tcorey
    More info: I am getting the same error when I try to use one of the curved subassemblies in the Curve_Example.pkt downloaded from the Wiki Help.
    Tim Corey, Owner
    Redding, CA
    Valued Mentor
    fcernst
    03-07-2013 05:09 PM in reply to: tcorey
    You are using an Auxillary Point for an end point... they don't get drawn.
    Ernst Engineering
    Fred Ernst, PE
    C3D 2013 SP1, C3D 2014
    W7x64; i7 8gb; Radeon HD 5700
    www.ernstengineering.com
