• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    krismcdonald23
    Re: Curve Calculator - Degree of Curvature
    01-07-2013 08:51 AM in reply to: Jeff_M
    Jeff, That's exactly what I'm seeing also.
    Please use plain text.
    dsigman
    01-07-2013 12:14 PM in reply to: Jeff_M
    I'm running version 2012 with the service pack installed and it works fine when I click on an arc. Not the OP's arc but one I drew.
    Member
    krismcdonald23
    01-07-2013 01:46 PM in reply to: dsigman
    dsigman, thanks for the input.  It seems to be limited to 2013 and something to do with a bug in the unit arc length.
    01-07-2013 02:20 PM in reply to: dsigman
    Correct, works fine in 2012 for me as well. This issue is limited to the 2013 product.
    Valued Contributor
    01-07-2013 04:09 PM in reply to: krismcdonald23
    I have the same issue in 2011, with the service packs installed.  To make it work, change the "Fixed .." from Delta to Radius. Then input the info you want and see if it doesn't work.  Aggravating, but it works.
    Surveyor Lee
