• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    krismcdonald23
    Curve Calculator - Degree of Curvature
    361 Views, 14 Replies
    01-06-2013 10:42 AM
    Related to Civil 3D 2013.  I'm trying to use the curve calculator to obtain values of a curve.  The problem is the value for Degree of Curvature is 00d00'00" everytime.  Is this broken in 2013 or is there some ambient setting I need to set? I've attached a screen shot.
    Many Thanks,
    Please use plain text.
    *Expert Elite*
    Re: Curve Calculator - Degree of Curvature
    01-06-2013 11:14 AM in reply to: krismcdonald23
    Have you installed the Service Pack? I have, and it appears to work correctly for me. Although the readme does not say this was an item that was corrected.
    *Pro
    01-07-2013 05:33 AM in reply to: krismcdonald23
    I get the same result with the curve calculator and I do not have the service pack installed.
    Dan
    Civil 3D 2013
    Win 7 Pro x64
    Intel Xeon 2.0GHz
    6Gb Ram
    ATI Firepro 4800
    Dell T5500
    www.preinnewhof.com
    *Pro
    01-07-2013 05:35 AM in reply to: dgordon
    I tried this on my 2011 version with all service packs installed and the curve calculator worked normally.
    Dan
    Civil 3D 2013
    Win 7 Pro x64
    Intel Xeon 2.0GHz
    6Gb Ram
    ATI Firepro 4800
    Dell T5500
    www.preinnewhof.com
    Member
    krismcdonald23
    01-07-2013 06:49 AM in reply to: krismcdonald23
    I have SP 1 installed but still get 0 for Degree of Curvature.
    *Expert Elite*
    01-07-2013 08:02 AM in reply to: krismcdonald23
    Ditto,
    2013 SP1 and "0" for degree of curve here.
    Jeff,
    Can you post your test drawing to make sure it's not a drawing thing. I did try with my template AND the NCS standard though.
    Bruce Klug
    AutoCAD Expert Elite
    AutoCAD Civil 3D 2013 Certified Professional
    C3D 2013 (SP1)
    C3D 2014 (Testing)
    Win 7 Pro, 64-bit
    *Expert Elite*
    01-07-2013 08:25 AM in reply to: klugb
    Bruce, I used the stock NCS dwt to test with.
    *Expert Elite*
    01-07-2013 08:29 AM in reply to: klugb
    Here's a setting to check, since I just noticed the OP's unit arc length is 0
    *Expert Elite*
    01-07-2013 08:35 AM in reply to: Jeff_M
    The mystery continues!
    Bruce Klug
    C3D 2013 (SP1)
    C3D 2014 (Testing)
    Win 7 Pro, 64-bit
    *Expert Elite*
    01-07-2013 08:45 AM in reply to: klugb
    OK, so looks like there is a bug when selecting the curve. If you input the values to calc a curve, without first selecting a curve, the DoC works correctly. As soon as you select an arc in the drawing, the unit arc length gets set to 0.
