• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Expert Elite*
    Accepted Solution
    Curb doesn't follow Edge of Pavement
    199 Views, 10 Replies
    01-23-2013 06:27 AM
    I've just set up a corridor.  It's got five regions.  I needed a few tapers so I used polylines to set targets.  Here's the thing: The LinkOffsetAndWidth is following the target that I set, but the curb which should be attached to the Link is ignoring the target.  i.e. the curb appears to be becoming detached from the link that it is set up with in the assembly.
    Here's a screenshot.  The red lines are my targets, the white is the corridor.  I circled in blue the problem areas.
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    Please use plain text.
    Valued Mentor
    fcernst
    Re: Curb doesn't follow Edge of Pavement
    01-23-2013 06:38 AM in reply to: troma
    Not sure unless there is a problem with that polyline perhaps, but you realize, you are going to want to use an Offset Assembly, to get correct perpendicular Corridor projections for your curb and gutter system relative to the horizontally transitioning Target alignment.
    Ernst Engineering
    Fred Ernst, PE
    C3D 2013 SP1, C3D 2014
    W7x64; i7 8gb; Radeon HD 5700
    www.ernstengineering.com
    *Expert Elite*
    01-23-2013 06:43 AM in reply to: fcernst
    You assume that I realize things that I may not realize.  I think you use corridors much more than I do.  I've read a few comments about things being or not being perpendicular, but it all flew over my head a little.  Do you care to elaborate?  How and why does one go about using an Offset Assembly?
    *Expert Elite*
    johnm
    01-23-2013 06:46 AM in reply to: troma
    If you don't have a profile to use with the offset I think you could also try to add more sections or increase the sampling frequency in these areas.
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    6 GB RAM, Quadro FX 1700
    *Expert Elite*
    01-23-2013 06:50 AM in reply to: johnm
    I found the problem in the south-east.  My target wasn't long enough.  (You can see in the original picture that nothing was following it past a certain point.) But the other problems remain.
    I increased my frequency to 1.0m on tangents and 0.1m on curves.  Nothing changed with the curb.
    *Expert Elite*
    01-23-2013 07:23 AM in reply to: troma
    I can only surmise that the curb is not actually attached to the link.  Look in your assembly properties, construction tab and see that everything is in there attached nicely.
    Also, if you adjust the width of the link in the assembly layout, does the curb follow it?
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
    *Expert Elite*
    01-23-2013 07:31 AM in reply to: mathewk
    No, they're not attached.  I was just going to post that, I noticed before I read your reply.  If I edit the lane to be 2m instead of 3m, the curb stays where it is:
    So what do I do to fix that?
    I don't follow your instructions about attching them back.  Thanks.
    *Expert Elite*
    01-23-2013 07:43 AM in reply to: troma
    Right click the curb and select add to assembly or move to, depending on what needs to be done.
    Matt Kolberg
    *Expert Elite*
    01-23-2013 07:56 AM in reply to: mathewk
    I had to click "Move to" first, which appeared to move it to somewhere in the middle of nowhere.  Then I had to click on "Clear Offset in Assembly" becasue I guess there was an offset set from baseline that held it in place.  Once this was cleared, the curb was actually attached and moved with the link when made wider and narrower.
    Thanks!
    Valued Mentor
    fcernst
    01-23-2013 09:18 AM in reply to: johnm
    Unfortunately, no amount of sampling frequency addresses the corridor perpendicularity projection problem for transitioning corridor systems.
    Ernst Engineering
    Fred Ernst, PE
