• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    richard.porter
    Crown Feature Line missing OverlayMillandLevel2
    108 Views, 3 Replies
    11-20-2012 12:11 PM
    I am having trouble with the Crown Feature line not displaying for the full length of my Corridor.
    I am running the OverlayMillandLevel2 subassembly using the minimum clearance setting. I then want to extract the corridor crown line profile, but because there are sections missing I can not extract the entire crown line in one length.
    I also have the problem of the crown feature line 'cutting' the corner, alongside the correct crown feature line.
    The attached image shows the problems I am having.
    Has anybody experienced this before? or know what the issue or fix might be?
    Please use plain text.
    *Expert Elite*
    sboon
    Re: Crown Feature Line missing OverlayMillandLevel2
    11-20-2012 12:54 PM in reply to: richard.porter
    The feature lines in your corridor look similar to a bug that I have reported previously.  Are you running with SP 2.1?  See this thread for more details.
    http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Civil-3D-Service-Pack-2-1-HEADS-UP/m-p/3603270/highli...
    Member
    richard.porter
    11-20-2012 06:30 PM in reply to: sboon
    I have run the design through 2012 w/ SP2.1 and 2013 w/ HF2.1 and still come up with the same issues. All of our current design is being carried out in 2013.
    The HF did stop the feature line 'cutting' corners, but there are still the gaps in the feature line running along the corridor.
    Do you still encounter the same bug with feature lines?
    *Expert Elite*
    sboon
    11-20-2012 11:44 PM in reply to: richard.porter
    Yes, I first noticed it in the original 2013 release.  It appeared in 2012 after the installation of SP 2.1
    Interesting that it seems to have been fixed in one version but perhaps not the other.
