• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    Cross section with Sample lines problem
    141 Views, 6 Replies
    01-13-2013 07:40 PM
    I have my surface, aligment and sample lines created, but I cant get my sample lines profiles.
    The grid apperas without data, it is like I have never selected a surface, but I did !
    This is what I get , totally empty
    Please use plain text.
    *Expert Elite*
    Re: Cross section with Sample lines problem
    01-13-2013 09:00 PM in reply to: sakuramukuro
    Layer froznn? Style messed up? Go to the section view properties and Section tab. Does it show a section with appropriate values?
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
    *Expert Elite*
    TRogers
    01-14-2013 06:22 AM in reply to: sakuramukuro
    This is probably due to not sampling the correct surfaces.  If you click on one the the sample lines, in the contextual ribbon, select Sample More Sources.  If your surfaces are in the left pane, add them to the right pane.
    If the issue was resolved by this method, please click on "Accept As Solution"
    *Civil 3DJ*
    Todd Rogers
    Visit my blog here.
    Valued Mentor
    LisaPohlmeyer
    01-14-2013 06:55 AM in reply to: sakuramukuro
    Is the surface set to display?  The sections won't display if the surface is off.
    Lisa Pohlmeyer
    Williamson Co. Dept. of Infrastructure
    Intel i7 3.33Ghz, 16Gb RAM
    Nvidia Quadro 2000D
    C3D 2012 SP3, C3D 2014
    Win 7-64
    Please mark this as the solution if it resolves your issue.
    *Expert Elite*
    TRogers
    01-14-2013 06:59 AM in reply to: LisaPohlmeyer
    The surface being set to No Display has no affect on the cross sections.
    *Civil 3DJ*
    Todd Rogers
    Visit my blog here.
    Valued Mentor
    LisaPohlmeyer
    01-14-2013 11:33 AM in reply to: TRogers
    Todd
    I could have sworn that used to be the case, maybe in a previous version, and by habit I still keep my surfaces visible.
    Lisa Pohlmeyer
    Nvidia Quadro 2000D
    Win 7-64
    *Expert Elite*
    sboon
    01-14-2013 11:39 AM in reply to: TRogers
    If the No Display style has been set to not display in Section mode then it won't show up in section views.
    My template has two surface styles.  One is NoDisplay which means that the surface does not show in any mode.  The other is NoPlanDisplay which is used for surfaces that I want to see in section views, or the corridor editor etc.
