AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Cross section points lable Northing Eastin
- Highlight
- Email to a Friend
- Report Inappropriate Content
can i lable a point in section view with its northing and easting? i can only lable offset and elevation for thr points.
Civil 3D 2013
HP Pavilion dv6 cor i7
16GB RAM
windows 8
Re: Cross section points lable Northing Eastin
- Highlight
- Email to a Friend
You need to add referance text to the label.
The only item which will give an easting and northing is a Cogo Point.
Place them in MS over the section line where you want them and project them to the veiw.
Add the label with CogoPoint Referanced text add text for Easting & northing then select the cogo point for the label. can also annotate the Point name on the view using this method.
- Highlight
- Email to a Friend
i understand that only cogo points can do that. What do u mean by MS? and wt if the project is large and i want the northing easting of all benches?
Civil 3D 2013
16GB RAM
windows 8
- Highlight
- Email to a Friend
MS = Model space.
If the project is large it just means a lot of work. You can project object using the section view group lines in plan. Run project to section view then select the section line and then points.
Obvously you will only project those points close to the section and not all of them.
- Highlight
- Email to a Friend
But how can u project the ponts exactly at the benche point?
Civil 3D 2013
16GB RAM
windows 8
- Highlight
- Email to a Friend
After following this post for a few days . . . If you have a break in elevation showing up in a cross section, can you not make it appear in the plan view also? Label the point in the plan with "X, Y, Zs".
Bill
