AutoCAD Civil 3D
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: Creating surface with polylines
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-19-2012 10:56 AM in reply to:
sdhauban
Changing the units isn't going to change the elements. You need to scale the objects in the drawing by a factor of 1/12 (0.083333333). You can do this either before or after you make the surface.
Cheers,
Peter Funk
Peter Funk
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-19-2012 12:30 PM in reply to:
peterfunkautodesk
Except that I think he said the objects are incorrect in their elevations only. Scaling will mess up the x and y.
If that's the case, here's a lisp routine that will change only the elevations of your objects. This will select all LWpolylines not on frozen layers, so freeze all layers except the layers that contain your contours/polylines.
Use Appload to load the routine. It will run automatically upon load.
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
Redding, CA
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-27-2012 11:07 AM in reply to:
tcorey
tcorey that worked!
Thank you guys so much!
