• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Employee
    Re: Creating surface with polylines
    11-19-2012 10:56 AM in reply to: sdhauban
    Changing the units isn't going to change the elements. You need to scale the objects in the drawing by a factor of 1/12 (0.083333333). You can do this either before or after you make the surface.
    Cheers,
    Peter Funk
    Peter Funk
    Please use plain text.
    11-19-2012 12:30 PM in reply to: peterfunkautodesk
    Except that I think he said the objects are incorrect in their elevations only. Scaling will mess up the x and y.
    If that's the case, here's a lisp routine that will change only the elevations of your objects. This will select all LWpolylines not on frozen layers, so freeze all layers except the layers that contain your contours/polylines.
    Use Appload to load the routine. It will run automatically upon load.
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    Member
    11-27-2012 11:07 AM in reply to: tcorey
    tcorey that worked!
    Thank you guys so much!
