• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    JamaL9722060
    Creating points at the stations of an alignment,
    181 Views, 4 Replies
    10-18-2012 01:43 PM
    I wanted to get the (x,y,z) of the stations of an alignment, but sounds not to work.
    In the screenshots below, I got the message “The specified station is not valid for this object” and couldn’t proceed! How this issue might be solved?
    Thank you
    Best
    Jamal
    Jamal NUMAN, GIS and Civil Engineer, MSc
    e-mail: JamaL9722060@yahoo.com
    P.O.Box: 731, Ramallah, West Bank, Palestine.
    Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
    Windows 7 (Ultimate 64 bits),
    Firefox 20.0,
    Kaspersky 2013.
    Please use plain text.
    *Expert Elite*
    Joe-Bouza
    Re: Creating points at the stations of an alignment,
    10-18-2012 08:14 PM in reply to: JamaL9722060
    Jamal,
    Home>> Points >> create point along alignment. key in a value that is within the station range
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    JamaL9722060
    10-19-2012 12:52 AM in reply to: Joe-Bouza
    Thank you Joe-Bouza for the help.
    I couldn’t find the option “create point along alignment”! the screenshot is attached.
    Firefox 20.0,
    Kaspersky 2013.
    Active Contributor
    bpoleuca
    10-19-2012 01:41 AM in reply to: JamaL9722060
    The function DIVIDE you can use when you want a number of segments.
    The function MEASURE you can use when you want to have the lenght you need and at the last portion you will have a diferent lenght. So I think you can use MEASURE.
    PS.
    1. How can I give the profile in reference to take the Z value?
    2. If you want to have X,Y,Z you must use points from coridor?
    JamaL9722060
    10-19-2012 01:57 AM in reply to: bpoleuca
    Many thanks
    To answer your two questions, please, have a look on the screenshots below.
    My issue is how to create points (in a group say g3) at the stations of the alignment! That’s all!
    Firefox 20.0,
    Kaspersky 2013.
