• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    neilyj
    Creating an Assembly Offset
    277 Views, 7 Replies
    09-19-2012 01:06 PM
    I've just been looking at the Assemlby Offset but not sure what it is useful for - please can someone enlighten me???
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    Please use plain text.
    Re: Creating an Assembly Offset
    09-19-2012 02:22 PM in reply to: neilyj
    With assembly offset and ETW target
    With normal assembly, same target.
    The offset needs its own alignemtn AND profile.  As you can see, you are not limited to your corridor sections being perpendicular to the baseline alignment, instead they are perpendicular to the target alignment.
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
    Distinguished Contributor
    09-19-2012 03:31 PM in reply to: mathewk
    Very nice pictures, thanks for creating those.  What happens in the small gaps at the beginning and end of the offset region when you make a corridor FG surface?
    Win 7E 64-bit, Intel i7, 12 GB
    C3D 2012
    09-19-2012 03:35 PM in reply to: jeff_rivers
    I'm not sure why I don't have more sections near those gaps, but any surface would just triangulate across those areas.  There's a chance you'd have to swap a few edges to make the TIN correct.
    Matt Kolberg
    neilyj
    09-20-2012 12:56 AM in reply to: mathewk
    Thanks for this - I've never really looked at assembly offsets before as never had any need...:smileyhappy:
    neilyj
    Joe-Bouza
    09-20-2012 06:43 AM in reply to: neilyj
    I don't know if this has been fixed in 12 or 13 but in 11 you are not able to extract a feature line from an offset assembly and maintain dynamic connection to the corridor.
    Snip from my SR:
    Thank you for your update. That is part of the issue. You seem to be creating feature lines (links) with the offset assembly. The issue is that program is not able to create the feature line. I hope this will be fixed in the near future. Unfortunately I have no information when.
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    Valued Mentor
    fcernst
    11-13-2012 06:52 AM in reply to: mathewk
    Please program Civil 3D to have the capability to recognize that the subassemblies that are outside of a transitioning alignment have to be oriented perpendicular to that transitioning alignment for correct surface triangulation.
    Users now have to go through the extra work to set up an Offset Assembly, come up with a clever Profile scenario, (or a MarkedPoint configuration)  just to realize proper triangulation that should be occurring in the first place.
    Then the user has to keep the above mentioned extra Corridor, Assembly, Profile or MarkedPoint,  overhead in mind for the duration of the project. This type of non-elegant overhead unnecessarily detracts from the good aspects of Civil 3D.
    Super elevation axis of rotation is not supported with Offset Asemblies. Therefore, how does one get proper triangulation outside of the LaneSuperelevationAOR subassembly with superelevation?
    Fred
    Ernst Engineering
    Fred Ernst, PE
    C3D 2013 SP1, C3D 2014
    W7x64; i7 8gb; Radeon HD 5700
    www.ernstengineering.com
    Valued Mentor
    11-13-2012 07:43 AM in reply to: jeff_rivers
    These are probably due to the offset value between the channel line and the widening offset alignment being too small or zero, I get this a lot.
    Instead of assembly offsets insert a different subassembly or you could use a conditional "Target found" subassembly in this region as I do.
    If you then allow the two regions to overwrite each other by a small ammount or until they are perpendicular to the master alignment then you can erase the underlying subassemblies and you will have the gaps filled and ready for setting out (NB: a carefully positioned second conditional target found would also do this instead of edits).
    Obviously you still need to provide a profile for the offset alignment but the outside edges will be correct.
