• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Pro
    Creating a pipe network from a feature line...
    163 Views, 5 Replies
    10-03-2011 07:56 AM
    No matter what i set the default structure settings to, I cannot get the structures to come in with a sump that is not 2 feet when creating a pipe network from a feature line.  It's as if this command ignores the rules of the default structure.
    can anyone else creating a pipe network from a feature line and get the sump to come in as zero?
    I may post this to the wish area if i can determine this is a known unchangeable setting.
    creating structures by layout doesn't count since I have been able to do this successfully.
    I was developing a great idea for a workflow for placing initial design of a Sanitary Sewer, and this issue cropped up.
    Dan
    Civil 3D 2013
    Win 7 Pro x64
    Intel Xeon 2.0GHz
    6Gb Ram
    ATI Firepro 4800
    Dell T5500
    www.preinnewhof.com
    Please use plain text.
    *Expert Elite*
    Re: Creating a pipe network from a feature line...
    10-03-2011 08:14 AM in reply to: dgordon
    I am seeing this same issue in 2012. This should be reported as a bug/defect, not a wishlist item.
    10-03-2011 10:02 AM in reply to: Jeff_M
    Sump depth can be set in the structure rules to zero. It is now in all my rules, and structures now come in at zero depth.
    Windows 7 64-bit
    HP Z600 8 Gig RAM
    Civil 3D 2011
    10-03-2011 10:04 AM in reply to: ccoles
    Also, you can set the rule, then apply them to your structures after the fact.
    Windows 7 64-bit
    HP Z600 8 Gig RAM
    Civil 3D 2011
    *Expert Elite*
    10-03-2011 10:26 AM in reply to: ccoles
    My structure rules are all set at zero depth. These rules are ignored when creating a network from a featureline. Yes, they can be fairly easily changed after-the-fact, but the key is, if there is a default rule set, it should be used and not ignored.
    *Expert Elite*
    johnm
    10-03-2011 10:44 AM in reply to: dgordon
    I have not been able to get this to work since the 08 release. I have done a few networks from objects in each release since with the same results as the OP and rules setting the sump to zero.
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    6 GB RAM, Quadro FX 1700
