• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    New Member
    Accepted Solution
    Creating Points according to elevation
    183 Views, 3 Replies
    01-03-2013 04:51 AM
    Hello all,
    I have a number of 3D polylines that where exported from SDF previously created. They have numerous vertices, each one with a given elevation.
    Could someone help me by tellling me how can i create/highlight the higher and/or lower point in each 3D polyline??
    A different solution would be automatically breaking these polylines in slope changing points (i.e. high or low points).
    I understand that i can create points according to slope or elevation, but it has to be done manually, each poly at a time, and by tipping numeric values that i am sure that a powerfull software (as Civil 3D is) is able to calculate using the drawing information.
    Thank you very much in advance by your help.
    Rui
    Please use plain text.
    *Expert Elite*
    Re: Creating Points according to elevation
    01-03-2013 05:56 AM in reply to: rbprata
    Perhaps you will find THIS useful.
    *Expert Elite*
    AllenJessup
    01-03-2013 06:23 AM in reply to: rbprata
    You could create points on the polyline then sort the point list by elevation.
    New Member
    01-04-2013 02:59 AM in reply to: Jeff_M
    Dear Jeff,
    indeed i found what you sent me very usefull...thank you very much
    Best regards
    Rui
