• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    d_reno
    Creating CL Points from Profile
    131 Views, 5 Replies
    09-29-2011 06:58 AM
    hey,
    I need to extract centerline elevations from a finished CL profile. From reading other topics here it seems the way to do this is by extracting COGO points from the corridor model along the CL. This isn't really what I need, but I can create an ASCII file from the points and pull the elevation data in a spread sheet. But, is there a better way? And, what I would really like is to also extract the station value for each CL point. If I create an alignment label style that shows the elevation and station, can I then extract this label data to get it into a spreadsheet or ASCII file?
    To summarize - I want to pull finished CL elevation with its station from a corridor or profile and be able to import this data into a spreadsheet.
    I am using C3D release 2011, Win 7, capable machine, everything up to date.
    THANKS.
    David Renaud, RLS
    C3D 2012 on 64bit Win 7 all up to date
    Dell Precision 7core 8GB RAM
    NVIDIA Quadro FX 1800M
    LDT/C3D user since release 12
    Please use plain text.
    *Expert Elite*
    Re: Creating CL Points from Profile
    09-29-2011 07:38 AM in reply to: d_reno
    Why not use the Incremental Stationing profile report? It will save the station and profile elevation directly to an Excel file.
    Jeff_M, also a frequent Swamper
    d_reno
    09-29-2011 08:03 AM in reply to: Jeff_M
    Thanks Jeff,
    Why not indeed? Thanks for the advice.
    dr
    David Renaud, RLS
    d_reno
    09-29-2011 08:26 AM in reply to: d_reno
    Well, that creates an XML file. Profiles_in_CSV creates an Excel file, but it doesn't create what I select/deselect. Still, if I want stationing the solution seems to be in a report, so I will keep plodding away. Is it possible to create custom reports without getting into code?
    thanks again.
    David Renaud, RLS
    *Expert Elite*
    09-29-2011 08:44 AM in reply to: d_reno
    It creates an XLS file for me....Excel Spreadsheet, which opens in Excel,
    d_reno
    09-29-2011 09:25 AM in reply to: Jeff_M
    Yep, my mistake. I didn't look close enough when I checked out files of type. As it is I copied/pasted into Excel and it placed the data into cells so I am off and running.
    thanks for your help.
    David Renaud, RLS
