• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    Create pipe network from multiple objects?
    160 Views, 4 Replies
    12-14-2012 09:27 AM
    Can I create a pipe network from multiple objects?
    For example, I have 10 feature lines that I want to use to create one pipe network. Instead of creating 10 pipe networks one at a time, can I create one pipe network all at once?
    Thanks.
    Please use plain text.
    *Expert Elite*
    Re: Create pipe network from multiple objects?
    12-14-2012 09:50 AM in reply to: rhdins
    You would need to join the feature lines into one first.
    Use the Joinfeatures command.
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    *Expert Elite*
    12-14-2012 09:54 AM in reply to: tcorey
    That may not be possible, eg if the features aren't connected end-to-end but branching off in different directions, or not touching at all.
    Another option is to create 10 networks, then merge them together.
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    The feature lines aren't connected.   That's what I've be...
    12-14-2012 09:57 AM in reply to: troma
    That's what I've been doing, is creating multiple pipe networks, then merging them.  I would like to be able to select all 10 feature lines and create one pipe network.
    Any other ideas?  Maybe it's just not possible?
    Thanks.
    Valued Contributor
    C3D_TomR
    Re: The feature lines aren't connected. That's what I've be...
    12-20-2012 04:09 PM in reply to: rhdins
    I like tcorey's suggestion. Add additional feature lines just to connect them for creating the network then joinfeatures. After you create the network from the single feature line, you can delete those dummy pipes from the network. Maybe mark the ones that need to be deleted with a magenta circle near the midpoint until the pipes are deleted from the new network.
