• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    IanMcClain
    Create feature line from object
    135 Views, 2 Replies
    10-09-2012 04:27 PM
    I use the create feature lines from object command from the Survey pull-down menu and choose a "Associate figure survey point to verticies" I get a survey figure that uses point elevations at some vertieces and 0 at others. However, if I use Create Feature Lines from Objects under the Grading pull-down, and use a surface made of just the points, I get a a figure with all the correct elevations.
    I checked the vertices where the survey figure drops to 0 and the line is snapped to the point, distance = 0.0000. What gives?
    -Ian McClain
    (running C3D 2012 sp3, Win7 64bit)
    Please use plain text.
    Product Support
    Re: Create feature line from object
    10-12-2012 08:56 AM in reply to: IanMcClain
    I tested this in a newer version than 2010 and it seems to work fine, but I may be missing something. Does it happen with all data or just a specific drawing?
    Seth Hall
    Product Support
    GCSO - CSS - FTS
    Autodesk, Inc.
    Being Civil
    Being Civil Twitter
    Being Civil Facebook
    IanMcClain
    10-12-2012 09:07 AM in reply to: SethHall
    This was the first time I have had it happen. I think it may be caused by re-importing survey events. Somehow that breaks the asociation between the snapped poly-line and the point. However, all my points are "at-elevation" set to 0. I assumed that the create featureline from object had some kind of tolerance to associate the verticies with nearby points. In this case the verticies with resulting 0 elevations are still right on the re-imported survey points. (re-import occured before the figure was made, but after the polyline was made.)
    -Ian McClain
