• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    Accepted Solution
    Create cross sections in a separate drawing
    302 Views, 6 Replies
    11-22-2012 07:50 PM
    I want to create cross sections in a blank drawing via a Data shortcut Project.
    My intent is to keep my file size to a minimum. I can include surface, alignment and profile per data shortcut
    but not my corridor. My corridor is 3000 feet long and when I do cross sections in the
    same drawing, it runs real slow.
    Thanks John Wilson
    Please use plain text.
    *Expert Elite*
    Re: Create cross sections in a separate drawing
    11-22-2012 08:40 PM in reply to: johnwilson0805
    Xref the corridor drawing into the sections drawing. You still need the alignment Dreffed, and possibly the surfaces, but the corridor will be picked up through the xref.
    Valued Contributor GZE
    Valued Contributor
    11-22-2012 10:04 PM in reply to: johnwilson0805
    You can also create the crosssections in three separate files say 1000 feet each. Just dref the alignment and the design profile and xref the corridor in each file. No need to dref surfaces c3d will extract them from your corridor file.
    Humphrey GZE
    Civil 3D 2013 64bit SP1
    Elitebook 8540w
    Core i7 2.8GHz, 8Gig RAM
    NVIDIA Quadro FX880
    160Gb SSD
    *Expert Elite*
    BrianHailey
    11-23-2012 09:21 AM in reply to: GZE
    No need to bring in your profile for cross sections either as cross sections don't care about profiles.
    Active Contributor
    11-24-2012 07:57 AM in reply to: Jeff_M
    Thanks Jeff it works great That what others have said too
    Active Contributor
    11-24-2012 07:58 AM in reply to: BrianHailey
    Thanks Brian. I learned alot. it works great
    Active Contributor
    11-24-2012 08:00 AM in reply to: GZE
    Thanks Humphrey
    It sure saves me time it runs fast
