• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    Accepted Solution
    Create Grid in Model space
    315 Views, 14 Replies
    01-09-2013 08:15 AM
    I am using  Civil3D 2012 and I am trying to create a 50'x50' grid in model space that automatically populates the N & E. Can anyone point me in the right direction?
    AutoCAD Civil 3D 2012 SP2
    Windows 7 (64)
    Please use plain text.
    *Pro
    Re: Create Grid in Model space
    01-09-2013 08:22 AM in reply to: jamesbarnett
    Cogo points can be populated based on a 50 x 50 grid and have a label style that just shows northing and easting.
    Dan
    Civil 3D 2013
    Win 7 Pro x64
    Intel Xeon 2.0GHz
    6Gb Ram
    ATI Firepro 4800
    Dell T5500
    www.preinnewhof.com
    Active Contributor
    01-09-2013 08:28 AM in reply to: dgordon
    I'm not wanting to create points though. I just need the lat long lines and an annotation. Carlson has the command dgrid, but I'm not sure how to do it in Civil3D.
    Windows 7 (64)
    *Expert Elite*
    AllenJessup
    01-09-2013 08:43 AM in reply to: jamesbarnett
    Use the MAPLAYOUTREFERENCESYSTEM to create the grid in a layout. Then use CHSPACE to move it to Modelspace.
    *Expert Elite*
    sboon
    01-09-2013 12:40 PM in reply to: AllenJessup
    You can set up a Note label style to display two lines and a coordinate at the intersection.  You can also create a dynamic block to do the same thing.
    Active Contributor
    01-09-2013 01:56 PM in reply to: AllenJessup
    I get this error
    c:\program files\autodesk\autocad civil 3d 2012\acmapgridsystem.arx cannot find
    a procedure that it needs.
    Unknown command "MAPLAYOUTREFERENCESYSTEM"
    Windows 7 (64)
    Active Contributor
    01-09-2013 03:38 PM in reply to: sboon
    Steve,
    I figured out the note, but I can't seem to make it offset a specified distance. I tried to use the array, but I can't figure out how to make the thing work.
    Windows 7 (64)
    *Expert Elite*
    AllenJessup
    01-10-2013 04:33 AM in reply to: jamesbarnett
    Have you installed SP1?
    Active Contributor
    01-10-2013 05:23 AM in reply to: AllenJessup
    The only sp update I get is for SP 2.1
    Windows 7 (64)
    Active Contributor
    01-10-2013 05:53 AM in reply to: jamesbarnett
    After updating to SP 2.1 the mapreference works great!
    Thanks guys now I have 2 options on performing the same task. If I could just get the note to offset at a specified distance that would speed up that option.
    Windows 7 (64)
