• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    phareouh
    Crash-Not Loading- Freeze-Opening Drawing/ Civil 3D-2012-x64
    424 Views, 7 Replies
    04-27-2012 11:44 AM
    Hi there,
    i usually get stock at this screen , usually what happen is i click "Continue" and it load the Helpvideo screen and i start working but now nothing ... just nothing
    when i had this before i try to restart smetimesitworksometimes it's just load me the Autocad 2012 "Non-Civil3D" .
    hope for your help
    Regards
    Yeah Will Not that much :
    Sony VPCCW26FA
    Intel Core i5 M 520 @ 2.40GHz
    8192MB RAM
    NVIDIA GeForce GT 330M 512MB Dedicated
    Please use plain text.
    Valued Mentor
    owenmull
    Re: Crash-Not Loading- Freeze-Opening Drawing/ Civil 3D-2012-x64
    04-27-2012 11:54 AM in reply to: phareouh
    phareouh wrote:
    Hi there,
    hope for your help
    Regards
    I dont see a problem at all.
    You are opening a drawing not created in the free student edition of Autocad that always plots with a stamp on it. You can still do most anything you want, but cant really plot or transmit anything.
    As far as the error goes, what exactly is the problem? It is freezing up after you continue? Wont save?
    Some more details could be helpful.
    If it wont open, I'd suggest running recover on it, and then an audit and a '-purge' Try that.
    -Owen
    Windows 7 x 64 bit
    ATI FirePro V4800 Triple Monitor
    12 GB RAM
    Intel Xeon W3550 @ 3.07 GHz
    Civil 3D 2012 SP 2
    ______________________________________________________________
    Intel inside. Idiot outside.
    Usually, I find that the problem is between the keyboard and the chair.
    Active Contributor
    phareouh
    04-27-2012 12:25 PM in reply to: phareouh
    Ah sorry , The Thing is It freeze and i can't click " Contiune" even the click icon is not highlighted.
    So it Freeze on that basies and i  don't crash and my Windows doesn't tell me it's not resposing ,
    and pease note that only the C3D is the freeze part the other windows application ar doing Fine.
    Sony VPCCW26FA
    8192MB RAM
    04-27-2012 12:28 PM in reply to: phareouh
    do you have a process called WsCommCntr* running active? If so try to kill this process (in the taskmanager).
    Does Civil3D then return to life?
    - alfred -
    Alfred NESWADBA
    Active Contributor
    phareouh
    04-27-2012 12:47 PM in reply to: alfred.neswadba
    Yeah a Bit Laggy But it worked , how to fix that in the future ?!
    Sony VPCCW26FA
    8192MB RAM
    04-27-2012 12:50 PM in reply to: phareouh
    >> But it worked
    Great, so you have a chance now: search for disabling communication center (>>>one sample of how to do that<<<) and you would not have this problem any more. Be careful when doing a repair-install or a servicepack-install, then you might have to disable it again.
    - alfred -
    Alfred NESWADBA
    Active Contributor
    phareouh
    04-27-2012 01:30 PM in reply to: alfred.neswadba
    - alfred -
    Du you mean : enable?
    Sony VPCCW26FA
    8192MB RAM
    04-27-2012 01:47 PM in reply to: phareouh
    besides of the language I use (German) this screenshot shows you where to find the entry in the registry for Civil3D2012:
    No, I meant really 'disable'.
    If you install a servicepack the commcntr is back alive, so you have to disable it again (after installing sp)
    - alfred -
    Alfred NESWADBA
