AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Corridors created by the junction tool - set up
- Highlight
- Email to a Friend
- Report Inappropriate Content
Is there a way to change the default Style Set that is used by the tool?
I don't want [All Codes] to be used, and since I created a style for the project I'd want to be able to use it when creating corrridor using the tool.
Toolspace Settings seem not to have relevant option.
Any clues?
Re: Corridors created by the junction tool - set up
- Highlight
- Email to a Friend
I'm not sure what you mean by Junction Tool, unless you mean Intersection.
If that's the case, the Intersection tool uses the default Code Set Style you have set by going to Settings tab of Toolspace, find Corridor, right click and select Edit Feature Settings. Set the default code set style under Default Styles.
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
sRe: Corridors created by the junction tool - set up
- Highlight
- Email to a Friend
Yes i mean Intersection.
I changed settings for both corridor, and simple corridor, but when I "Rrecreate Corridor Regions" the tool still uses [ALL Codes] ![]()
Re: sRe: Corridors created by the junction tool - set up
- Highlight
- Email to a Friend
There is no Simple Corridor at the level I am referencing. Sounds like you're drilling down to Corridor --> Commands --> Create Corridor and Create Simple Corridor. Please re-read my previous post and go to Feature Settings for Corridor at the first Corridor level of Settings tab.
Redding, CA
- Highlight
- Email to a Friend
Thanks Tim-
Managed to make it work
