• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Accepted Solution
    Corridor surface will not fill entire corridor
    191 Views, 12 Replies
    01-16-2013 12:58 PM
    It seems as though the surface is being cut off.  How can I fix this from happening?  See attached picture.
    Please use plain text.
    *Expert Elite*
    Re: Corridor surface will not fill entire corridor
    01-16-2013 03:15 PM in reply to: nhuckla
    It might be one of your subassemblies.  Attach an image that shows your assembly and describe which subassmeblies you've used.
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
    01-16-2013 03:23 PM in reply to: mathewk
    starting from the left of the assembly:
    1 General Daylight
    2 Basic Lane
    3 Basic Lane
    4 Basic Lane
    5 Basic Lane
    6 I tried linksloptosurface here but did not get the result I was looking for.  Still trying to find one.
    *Expert Elite*
    01-16-2013 03:43 PM in reply to: nhuckla
    How did you create your surface boundary?  You should have used "Corridor extents" or the feature lines dayight on one side and the road edge on the other..
    Matt Kolberg
    01-17-2013 08:03 AM in reply to: mathewk
    The picture attached is the boundary that I am using.  How do you use Corridor Extents?  Yes one side is daylight and the other is a lane subassm.
    *Expert Elite*
    01-17-2013 08:09 AM in reply to: nhuckla
    That image doesn't tell me anything.  how did you create that boundary?
    Matt Kolberg
    01-17-2013 08:12 AM in reply to: mathewk
    I created the boundary by setting it to daylight the top links.  Is this what you mean?
    *Expert Elite*
    01-17-2013 08:36 AM in reply to: nhuckla
    Yeah, that's what I mean. I'm not sure how you could have specified daylight as a boundary since you only have daylight on one side.
    Remove that boundary and use the interactive option then follow your outermost feature lines until the boundary is closed.
    Matt Kolberg
    01-17-2013 08:38 AM in reply to: mathewk
    Ok.  Thank you.
    *Expert Elite*
    01-17-2013 08:38 AM in reply to: nhuckla
    If you have 2013 you could select corridor extents as a boundary. If 2012, that option comes if you have more than one baseline...even if that other baseline is blank (hint).
    Matt Kolberg
